06-04-2021, 03:17 PM | #1 |
fuel leaks from carb intake
Float is set to 5/8 and fuel leaks from carb air intake . BTW when setting the 5/8 float height , is the needle vale susposed to be closed at that setting??
06-04-2021, 04:28 PM | #2 |
Re: fuel leaks from carb intake
Yes, the needle should be closed.
Is it a new needle, preferably a Viton tipped needle? If not, make sure there are not any scratches on the needle. Are you using one of these to set the height? https://www.snydersantiqueauto.com/P...earchByKeyword |
06-04-2021, 04:32 PM | #3 |
I assume Zenith. The float valve should be shut at the 5/8 inch position. See: http://model-a.org/float_valve_float.html
06-04-2021, 04:33 PM | #4 |
I think the valve is repop. How do I test the float ?
06-04-2021, 04:34 PM | #5 |
I have it at 5/8
06-04-2021, 04:40 PM | #6 |
06-05-2021, 05:34 AM | #7 |
To be clear, the gasoline level should be at 5/8 inch.
06-08-2021, 10:48 AM | #8 |
Often times I find this is due to the jets leaking where they screw into the carburetor. Pull the carb apart, pour some gas into the float bowl and look in the air intake. See if fuel is seeping up around the jets. Some jets have a small gasket, some have a taper fit. Make sure the seats are clean and the gaskets are in good shape.
Ken
Style beats speed any day, and with a lot fewer tickets. |
06-08-2021, 11:53 AM | #9 |
Zeniths: Causes of leaking
Problem: Remedy 1 Leaking/loose float valve gasket: Tighten/reseal/replace 2 Leaking float valve: (or crud stopping it sealing) Replace ( or clean up if possible ) 3 Friction on float hinge: Loosen 4 Incorrectly set fuel level: Re-set 5 Hole in float: Repair or replace 6 Too many gaskets on main jet Check 7 Cap jet or main jet too short: Replace 8 Leaking/loose gasket at main jet: Tighten/reseal/ replace 9 Leaking /loose gasket at cap jet: Tighten/replace 10 Leaking or loose GAV housing threads: Tighten/ reseal/ replace 11 Leak at fuel inlet union: Tighten/reseal/replace 12 Loose/leaking gasket at strainer: Tighten/reseal/replace 13 Loose/leaking gasket at drain plug: Tighten/reseal/replace 14 Cracked housing/leaking passage plugs: Repair or replace 1-7 will generally manifest as poor running. 8-14 will generally not affect running unless there is excessive leaking |
Thread Tools | |
Display Modes | |
