04-25-2019, 06:52 PM | #1 |
1952 f1 -dash throttle pull
So I am wondering what the linkage looks like to hook this up? I have the throttle ball on the carb,but how does the cable and ball connect,linkage?
04-25-2019, 07:08 PM | #2 |
Re: 1952 f1 -dash throttle pull
This help?
Thanks Andy 1952 F1 |
04-25-2019, 08:30 PM | #3 |
How about a picture on the driver side,where the pull throttle connects to!
04-25-2019, 09:19 PM | #4 |
Your hand throttle linkage should have a brass block with set screw for the cable end.
I dig coal, which provides motivation for EVs. |
04-25-2019, 11:55 PM | #5 |
I should be able to get a picture of mine tomorrow.
04-26-2019, 12:36 AM | #6 |
If you have a lever with a ball carb is set up for an older style vehicle. Then you need to change the lever and bracket holding the wire. |
04-26-2019, 06:38 AM | #7 |
Another will this help? This one missing the bracket to clamp the cable.
04-26-2019, 02:23 PM | #8 |
That's what my carb looks like!
04-26-2019, 02:24 PM | #9 |
That carb is for an older vehicle with rods for choke and throttle.
You need to add the double bracket and change the handthrottle lever to one for wire. |
04-26-2019, 10:26 PM | #10 |
Here's my 52 F3 carb. Hope this helps.
Scott |
04-28-2019, 02:29 PM | #11 |
Ok,now where can I get that linkage with that brass block?
04-28-2019, 06:36 PM | #12 |
Try Vintage Speed, www.vintagespeed.com
You'll have to wade thru their "Holley 94 Parts" section, but I'm pretty sure it is in there. edit: just checked, looks like they only have the Ball End type
'52 F-1, EAB flathead |
04-28-2019, 10:08 PM | #13 |
Maybe Charlie NY?
