Old 01-26-2020, 01:47 PM   #1
1935TOWtruck
Default Throttle pedal linkage
Can anyone tell me if gas pedal assembly is different on 1934 pickup and 1935 pickup thanks also is it same for 1935 to 1937 pickup
1935TOWtruck is offline   Reply With Quote
Old 01-27-2020, 01:42 AM   #2
deuce lover
deuce lover's Avatar
Default Re: Throttle pedal linkage
'34 different than '35. '34 has a smaller spoon and curverture of the arm is different.'35-'40 commercial ,same and has a longer shaped spoon.
deuce lover is offline   Reply With Quote
Old 01-27-2020, 09:36 AM   #3
Bigjohnson
I am building a 35pu looked far an wide went to chickasha swap meet thought I found the one not so found a 35 1ton in a junk yard in ok 35 an36are the same that’s what you need
Bigjohnson is offline   Reply With Quote
Old 01-27-2020, 08:19 PM   #4
1935TOWtruck
Thanks for the info
