Old 03-15-2020, 03:05 PM   #1
Bigjohnson
Default 31ford front brake
Does anyone have a picture of the front brake rod spring mount thanks fellas
Bigjohnson is offline   Reply With Quote
Old 03-16-2020, 08:48 AM   #2
CA Victoria
CA Victoria's Avatar
Default Re: 31ford front brake
The long anti-rattle spring is used up front, the bracket is stamped steel and on mine is riveted to the frame. It attaches with a 5/16-24 x 1” bolt to the bracket.
The knob goes ahead of the spring so tension holds the rod forward and eliminates “rattle”.
April 31 frame pictured.
File Type: jpg 950D4C93-4966-46FA-A279-706C88D93B63.jpg (37.5 KB, 32 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 03-16-2020, 08:52 AM   #3
DavidG
DavidG's Avatar
Per chance did you mean '32 rather than '31, given which site you're on? If so, the spring wire front brake rod supports used for most of the '32 model year are completely different from those used on Model As.
Old 03-16-2020, 09:07 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
"Big..." DOES own a '31 coupe. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-17-2020, 10:12 AM   #5
Bigjohnson
Sorry I am so used to going on early v8 I was talking about my 31did post on model a forum so sorry guys
Old 03-17-2020, 10:15 AM   #6
Bigjohnson
Thanks that is what I needed to see learn as I go thanks agin
