Old 07-04-2018, 09:34 AM   #1
Talkwrench
Talkwrench's Avatar
Default Crank Pulley
Are these light weight short snout crankshaft pulleys available as an aftermarket or stock item as for the life of me the ones I've found are all bent.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 07-04-2018, 01:56 PM   #2
john in illinois
john in illinois's Avatar
Default Re: Crank Pulley
john in illinois is offline   Reply With Quote
Old 07-04-2018, 02:23 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
They do get bent easily, especially if they are left on an engine that's been pulled out of a vehicle and set down on a shop floor. Then maybe moved around on the floor several times, that pulley takes a beating. They also get a groove worn in the diameter where the front seal rides. I doubt if anyone is reproducing them, but you might find someone who has a good used one for sale.
John
Old 07-04-2018, 02:36 PM   #4
deuce lover
deuce lover's Avatar
Not reproduced.There is a NOS one currently listed on EBAY.You can also use the later 39 dlx,40 /41 and cut off the flange that the fan mounts on.
Here is the link to the NOS
https://www.ebay.com/itm/1932-FORD-F...cAAOSwJvpalt3c
deuce lover is offline   Reply With Quote
Old 07-04-2018, 07:18 PM   #5
Talkwrench
Talkwrench's Avatar
Yes the link worked .. sweet mercy , pricey when you convert to AUD and postage !
I wouldn't be to worried about the worn grooves as I will put a sleeve over it for a one piece seal.
Old 07-04-2018, 07:52 PM   #6
uncle max
uncle max's Avatar
NOS... Never On Sale.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 07-05-2018, 06:16 AM   #7
Kahuna
Kahuna's Avatar
Why not get a good 59 type pulley & turn the outer sheeve off?
That's what I did for my 32. Works fine.
Or am I not understanding the issue?
Kahuna is offline   Reply With Quote
Old 07-05-2018, 10:20 AM   #8
cmbrucew
cmbrucew's Avatar
Fred at Southside Obsolete May have some. He is barnfind08 here on the barn.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 07-05-2018, 02:30 PM   #9
Brian
Brian's Avatar
The later pulleys' whilst you could machine off the front to suit, still have a bigger bore than the early pulleys, so would need to be sleeved to suit.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-05-2018, 03:11 PM   #10
Kahuna
Kahuna's Avatar
Thanks Brian
I was unaware of that
Jim
Old 07-05-2018, 07:12 PM   #11
Talkwrench
Talkwrench's Avatar
Yes it was the only straight one of the bunch I had , of course the lager bore became apparent..aghh..
Old 07-06-2018, 05:49 AM   #12
Ritzy1
Ritzy1's Avatar
Check with VanPelt. I was able to get a NOS single sheave pulley (81C-6312A) from them recently.
Ritzy1 is offline   Reply With Quote
