07-29-2015, 02:07 PM | #1 |
'40 Ford wing vent removal
I'm trying to remove the wing vent assemblies from the door garnish moldings on my coupe. Do the wing's lower bolts have to be pressed out of the two square id bushings that sandwich the lower brackets? I've used liquid wrench with light tapping on the bolt to no avail, along with drilling out the upper hinge rivets and removing the old seal and it's two end rivets. Thanks.
Bob |
07-29-2015, 02:20 PM | #2 |
Re: '40 Ford wing vent removal
Its stuck. The washers with the square holes slide off . Try alittle heat on the washers but dont heat the spring
07-29-2015, 02:21 PM | #3 |
Bob, There is no reason to remove the upper nor the lower brackets from the molding in order to remove the wing window assembly. Simply remove the lower pivot hardware - a cotter pin, slotted hex nut, a few washers and the bottom is now free. Then, remove the rivet at the upper "pivot" and the top is free.
You do have the molding removed from the door - yes???
07-29-2015, 02:42 PM | #4 | |
Thanks skidmarks and Kube for the advice. |
