Old 05-02-2022, 08:22 AM   #21
1931 flamingo
1931 flamingo's Avatar
Default Re: Water Soluble Grease
As was asked many posts above, what are you going to use the grease for??
Paul in CT
Old 05-02-2022, 01:39 PM   #22
California Travieso
Send a message via Yahoo to California Travieso
Paul in CT
This is a joke. As you noted he has refused to answer the question that many people have asked.
All he has to do is Google the question and he will get his answer. I Google it and I don’t think it has anything to do with Model A’s.
I’m moving on.
David Serrano
California Travieso is offline   Reply With Quote
Old 05-02-2022, 09:41 PM   #23
Forddan
I’m moving on.
David Serrano
I have been working all day and I just open the forum. Yesterday was Sunday and I had more time to read and answer. So please don't judge. I am not joking.
Let's go to my first posting question :
" anyone knows a water soluble grease that I can use to grease my water pump ? "
If there isn't one, then fine.
I appreciate the answers and the links I have received.
I am not really sure what is the question I haven't answer. On my first posting I was clear:
- looking for a water soluble grease
- for greasing my water pump.
If that was misunderstood then I am sorry. But I will appreciate very much to not judge someone without a justified reason.
All the best !!!
Daniel
Forddan is offline   Reply With Quote
Old 05-02-2022, 09:42 PM   #24
Forddan
Paul in CT
As stated on my first posting: to grease my Ford Model A water pump.
Old 05-02-2022, 09:43 PM   #25
Forddan
Originally Posted by jak View Post
Thank you very much for the link !!!
Daniel
Old 05-02-2022, 09:49 PM   #26
Forddan
Originally Posted by Synchro909 View Post
The fitting on the rear bearing of the water pump has a cap on it. I put some lube in the cap and screw it on, forcing lube into the bearing. With a good bearing, you will feel the resistance. I give it a half to one turn when I lube the distributor. (about 300 miles) If you think that is not enough, I suggest running a lubricating additive in the water, Like the Cyclo one I mentioned above.
Unfortunately I have a standard grease fitting to grease my water pump. Not one as you describe and I have seen in youtube videos
Thank you !!
Old 05-02-2022, 09:52 PM   #27
Forddan
Originally Posted by burner31 View Post
I use K-Y jelly in a lube cup
Thank you !! I have read about K-Y and I will give a thought to it. I wasn't able to find d the pictured lub cup that you mentioned. Probably I did a wrong search among the Model A vendors. I will try again tomorrow.
Thank you again for the tip !!
Daniel
Old 05-02-2022, 09:58 PM   #28
Forddan
Originally Posted by J Franklin View Post
Take your grease gun and give it 1 pump and measure the amount of grease that exits. Use the amount as a judgment on the number of pumps needed usually 1 or 2. Just don't take it to the local garage for a lube job! Want another grease area to worryt about? The zerks on the rear axle shafts need the same care in not overgreasing. 3-4 pumps there are all that is needed.
Thank you for the tip !!!. I read that others just unscrew the grease fitting and add the grease with the finger to pack the grease and avoid over-greasing.
If I do not find what I am looking for and I end using a "water proof grease" from the model A vendors or just the Marine lube many use, then I will carefully look to your technical suggestion.
Thank you again !!
Daniel
Old 05-02-2022, 10:27 PM   #29
J Franklin
J Franklin's Avatar
Use chassis grease was my recommendation! The grease fitting was added for a reason, not for ornamentation.
Old 05-03-2022, 05:13 AM   #30
Forddan
Thank you !! I will.
I ordered the Snyder's water pump grease. Arriving this Friday. I will buy a new grease pump only for this grease that i will also use on the chasis.
For the water pump I will first try the Finger Loading Technique and see how that results.
Best !!
Daniel
Old 05-03-2022, 07:01 AM   #31
ndnchf
ndnchf's Avatar
Not grease, but NAPA sells water soluble oil. I've used it for other purposes and it does in fact mix very well with water.
https://www.napaonline.com/en/p/WLD7...525&ir=1&tps=1
ndnchf is offline   Reply With Quote
Old 05-03-2022, 09:05 AM   #32
rotorwrench
rotorwrench's Avatar
A low melt point grease that still functions with moisture is what a person really needs. I use Lubriplate 130AA since it has a melting point lower than 180 degrees and will still have good lubricity when running with moisture.
A grease with a high melt point can clog radiator tubes if too much gets in there. Some folks use petroleum jelly or Vaseline. KY-Jelly was also mentioned. While both can be used in the presence of moisture, I don't know how well either one would be for metal to metal lubricity in high temp situations. Vaseline would have more lubricity than KY since KY doesn't contain any mineral base oil at all. It has water and glycerin as a base with antifungals and antiseptics. At least Vaseline has mineral oil & waxes for 100% of it's make up.
Old 05-03-2022, 10:00 AM   #33
katy
katy's Avatar
Originally Posted by Forddan View Post
If I do not find what I am looking for......
Grease cup: https://www.amazon.com/X-DREE-Machin...%2C718&sr=1-16
You may also find them at Tractor supply
