06-11-2019, 12:58 PM | #1 |
Hard to Start
The 48 has been running well. Has new wire, rebuilt generator, rebuilt coil, new voltage regulator (NOS). Has been starting easily hot or cold.
Yesterday evening I drove to a friends place and the car had sat for about 1.5 hours. When I tried to start it up I had plenty of cranking power but it would not fire. Tried starting fluid, still no fire. Removed a plug wire to see if there was spark and that time it started right up. This was about the third try after sitting for a few minutes between tries. I am wondering what to look at. |
06-11-2019, 01:36 PM | #2 |
Re: Hard to Start
I did not see "condenser" in you're list!! Many stories here on the barn of brand new ones being installed on one day, the next day they don't work!!!
06-12-2019, 10:43 AM | #3 |
Re: Hard to Start
IF I were you, I'd call Bubba's ignition (he is here on the barn) (And just saw he is having health issues) he has some good high quality condensers that he is having made (I believe & not cheap up front) but over the long haul they will get cheaper and cheaper when you have no more condenser issues!!! IF he doesn't have what you need he can suggest a source!!!
06-12-2019, 10:52 AM | #4 |
Re: Hard to Start
With respect, I wouldn't be bothering Bubba right now.
06-12-2019, 10:58 AM | #5 |
Re: Hard to Start
I would check 2 things: The contact brush and plate in the switch on the steering column, and the resistor. Either one can cause intermittent issues. I suspect during the "no start" time the wire to the coil was at zero or less then 4 volts.
06-12-2019, 11:33 AM | #6 |
Re: Hard to Start
06-12-2019, 12:00 PM | #7 |
Re: Hard to Start
06-12-2019, 12:05 PM | #8 |
Re: Hard to Start
06-12-2019, 06:41 PM | #9 |
Re: Hard to Start
Darrell S, Yes check the resister or jump around it next time it won't run. Also check the voltage coming to the coil. That resistance wire in the resistor can have a break where it still makes contact and the car runs but after it heats up, it pulls apart until it cools down again. I know of 2 cases where this has happened. Make sure your coil doesn't have an internal resistor if you have an external one. I am not familiar with the later (41-8) cars as to where the ignition resistor is.
06-12-2019, 07:26 PM | #10 |
Re: Hard to Start
Mike on the later cars the resistor sits right next to the coil.
06-12-2019, 08:53 PM | #11 | |
Re: Hard to Start
Just sayin'
Enjoy yer day. Tom Hate can't fix what it started. |
06-12-2019, 09:08 PM | #12 | |
Re: Hard to Start
06-12-2019, 09:15 PM | #13 |
Re: Hard to Start
Thanks Tom, I haven't owned any old Ford newer then 40. I am ignorant about them so now I at least know that. My hot rod cars have 59 series engines but have no idea how a stocker should be. My 33 is stock as well as the 40 wagon.
