03-30-2021, 01:24 PM | #1 |
Is some blowby normal?
im just getting the model a out for the year now that spring has finally sprung and the salt is washed off of the roads. I have noticed some oil is coming out of the oil filler neck and there seems to be a lot of air blowing out that seems to be bringing some oil vapor along with it. Is this somewhat normal? Ive seen some model a’s with what looks like a vent tube off of the filler kneck that vents underneath the car. Thats why im not sure if this is “normal” for the a’s or if i need to look into the possibility of a broken or seized ring. I have not done a compression test yet.
Good things take time |
03-30-2021, 01:30 PM | #2 |
Re: Is some blowby normal?
My bad. I jumped the gun with my post. I have now found that this has already been discussed. Back to the garage now.....
03-30-2021, 01:40 PM | #3 | |
Oil breather, will also keep the fire wall cleaner. Venders sell several different styles. Enjoy your car. |
03-30-2021, 07:19 PM | #4 | |
03-30-2021, 07:44 PM | #5 |
04-03-2021, 11:09 AM | #6 |
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
04-03-2021, 01:32 PM | #7 |
Rings are not a perfect seal even less so when worn. Pistons goes up, pull air in thru the vent tube, pistons go down push air out thru the vent tube.
I know the voices aren't real but damn they have some good ideas! |
04-03-2021, 04:19 PM | #8 |
With 2 pistons going up and 2 going down, the overall volume of the sump doesn't change. Any gasses exiting from the breather are purely the result of blowby, which as has been said, is inevitable.
04-03-2021, 04:47 PM | #9 |
I just got done doing a compression test. Cylinder one had 58psi the rest had 60psi. I installed the draft tube after doing the compression test. Weather is nice, its getting driven...
04-03-2021, 05:03 PM | #10 |
Off topic: When we were cruising our sail boat, there was a boat nameed "Blew-by-U" I guess they thought is was fast. Whenever there are two sailboats in the same water going the same direction, it is a race.
04-03-2021, 07:39 PM | #11 | |
https://www.youtube.com/watch?v=Kp9G0zkorio
