Old 04-01-2017, 12:29 PM   #1
Ian in Mississauga
Default Measuring camshaft lift
If I measure the diameter from heal to nose and then at a right angle to the first measurement ( the narrowest) will the difference be the lift?
Ian in Mississauga is offline   Reply With Quote
Old 04-01-2017, 12:36 PM   #2
MikeK
MikeK's Avatar
Default Re: Measuring camshaft lift
No. You will be measuring across the acceleration and deceleration ramps.
MikeK is offline   Reply With Quote
Old 04-01-2017, 12:47 PM   #3
redmodelt
redmodelt's Avatar
http://www.mtfca.com/discus/messages...tml?1491059157
Old 04-01-2017, 06:10 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I'd say, measure from the center of the cam to the highest point of the lobe, then measure from the center of the cam to the center of the heel.
Subtract the LITTLE number from the BIG number, and that's the LIFT!
There's probably a FORMULA, but I don't know it????---A dial indicator would work, also.
Bill Slightlystupid
"THE ASSISTANT GURU OF STUFF"
Old 04-01-2017, 06:22 PM   #5
Pete
Pete's Avatar
YES, in the case of a model A Ford original cam.
They were of the 3 arc design so the base circle is concentric.
There are no clearance ramps.
Old 04-01-2017, 06:31 PM   #6
Mikeinnj
Mikeinnj's Avatar
#2 says No
#5 says YES
Mikeinnj is offline   Reply With Quote
Old 04-01-2017, 06:59 PM   #7
Mitch//pa
Originally Posted by Mikeinnj View Post
#2 says No
#5 says YES
Go with #4. Dad knows his shit
Old 04-01-2017, 07:05 PM   #8
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Just a week ago I mounted an A-grind cam between centers in my lathe and used a dial indicator to measure (accurately!) the lift.It was the same as when measured as the OP described.
Did the same with a B-grind and the difference in lift was OTOO .050", the same as using the OP's method.
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 04-01-2017, 08:06 PM   #9
MikeK
MikeK's Avatar
#2 says No
#5 says YES
Pete is correct. It will work with the relatively primitive cam geometries. If it is a later profile, either new or regrind, at 90 degrees you may already be on a clearance ramp designed to take the inherent 'clack' out of a solid lifter cam. Then all bets are off. If it is an unknown cam use vee blocks and a height gauge or dial indicator.
Old 04-01-2017, 11:40 PM   #10
hardtimes
hardtimes's Avatar
#2 says No
#5 says YES
Hey Mike,
If you do not know Pete, then I understand your question.
Your answer is....Pete is a 50 some years of experience as...... CAM MAKER !
Pete builds and races cars and engines also.
There may be another here on this board, besides Jim B, who knows cams, but I would not question Pete's credentials where cam knowledge is concerned.
Old 04-01-2017, 11:58 PM   #11
Fullraceflathead
Fullraceflathead's Avatar
I was able to just catch the edge of a valve with my one inch travel indicator thru the spark plug hole. With the spark plugs out and car in high gear you can slowly move the engine. Zero out the indicator with the valve closed then push car slowly and you will see the rise and fall of the valve and lift. Mine was .287 lift which is correct for a stock cam with proper lashed valves.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-02-2017, 12:59 AM   #12
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Question: if your lift is , say 305, then is that the lift before the lash is subtracted or the total of the lift and lash.?
Old 04-02-2017, 02:56 AM   #13
Mike V. Florida
Mike V. Florida's Avatar
I like pictures,
http://www.lunatipower.com/Tech/Cams/CamSpecTerms.aspx
Old 04-02-2017, 07:30 AM   #14
MikeK
MikeK's Avatar
I like pictures too.
Here is a drawing showing clearance ramp locations that will clearly interfere with attempts at measuring the base circle 90 degrees to the lift.
Old 04-02-2017, 09:41 AM   #15
BILL WILLIAMSON
I "think" I once read that CLEARANCE RAMPS had something to do with using HYDRAULIC LIFTERS????---"Maybe" I'm just confused????
Bill W.
Old 04-02-2017, 02:39 PM   #16
Pete
Pete's Avatar
Checking on the master cams for 3 of the most popular street/touring grinds for the model A/B, there is no difference in lift as measured with micrometers or a dial indicator.
In other words, the clearance ramps start above or at the center line.
However, as the grind becomes more radical as in a drag race or circle track grind, this does not hold true. this is primarily because the base circle becomes smaller.
The readings can vary as much as .002 to .005.
For Bill W, the base circle on a hydraulic lifter cam is concentric.
