02-05-2014, 09:29 AM | #1 |
shop heat
Here in McMinnville Oregon I went to the shop to work on the A in 34 degree temp. Fired up the wood stove trying to get some heat in my 30x40 shop so I could get something done but after burning up 3 wheel barrow loads of wood 50 degrees was all I could get as far as warm. It's 24 now and I'm staying in the house.
What kind of heat are you using to get some work done?
Hotrods don't have valve covers |
02-05-2014, 09:35 AM | #2 |
Re: shop heat
Our low tonight here in Iowa is predicted to be -11 degrees. The shop is not heated, but the work room inside the shop is natural gas. The space is the size of a single car garage with room for work bench, and well insulated (6"). The temp can be set wherever I want it.
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
02-05-2014, 09:35 AM | #3 |
Re: shop heat
I use a 50,000 propane salamander, but it usually does not get that cold here. Go over to the garage journal .com , sister forum to this, and see suggestions there.
02-05-2014, 09:39 AM | #4 |
Re: shop heat
I use a hanging heater that is poweed by elec.
The secret is to insolate well. In cold (25) it takes it up to 60 in 15-20 min I find that warm enough and cost is low hear in Taunton. |
02-05-2014, 09:51 AM | #5 |
Re: shop heat
24 x 32 pole barn. Walls and ceiling insulated. Modine 30,000 BTU heater suspended from ceiling. Propane ($!) fired. Last week, with heat OFF, -10 outside temp was 48 degrees in shop. Heats up quickly. 250 gal tank usually lasts me 1 1/2 seasons. I only turn on heat when I am going to be working out there.
02-05-2014, 10:16 AM | #6 |
Re: shop heat
02-05-2014, 10:26 AM | #7 |
Re: shop heat
The best thing you can do for such a large space like that is to section off a smaller space, maybe 16x20 with an 8 or 9' ceiling and heat that. You end up with one area of the shop that you are able to keep free of shelves, tools, storage, etc. Just a dedicated workspace that you can either be messy in cutting woodwork or painting without contaminating everything else in the shop. You can build permanent walls, use heavy lumber tarps suspended on a steel cable to make curtains, I have seen it done several ways.
I know some guys that spend so much time trying to heat their huge shop in the winter, they never get anywhere on their projects. A guy needs a big shop because it ends up being a storage place for all kinds of things, but the actual work area doesn't have to be that big. I would rather have a warm small work space versus a cold huge storage building, however a man shouldn't have to choose between one or the other, he needs both. |
02-05-2014, 10:17 AM | #8 |
Re: shop heat
Used oil furnace, works very well, cheap, I can get 2-3 weeks on 250 gallons of used oil
The down side, every thing gets full of oil, (leaking barrels, spills, oil on hands and touch something) getting oil out of the shed with the forklift at -30 degrees and snow, wind comes out of the wrong way it will prevent the fire from staying lit and the sensor will stay cold so it will trip the reset and the furnace will stay off Other than that it is really nice , keeps the whole shop warm, we always run the fans to keep the heat towards the floor John |
02-05-2014, 10:23 AM | #9 |
Re: shop heat
None, I just work on warm days and for short periods, I hate it! Northern Bucks Co, Pa
Terry |
02-05-2014, 01:46 PM | #10 |
Re: shop heat
02-05-2014, 10:28 AM | #11 |
Re: shop heat
25 below zero here this morning. My current shop is pretty small, 12 x 24 I just use a propane tank mounted heater. Usually does a great job, I can't even leave ot on very long when the temps are in the teens. 100# Bottle of propane lasts about 2 years.
But I am also insulated pretty well.
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
02-05-2014, 10:40 AM | #12 |
Re: shop heat
For those of you that can not heat the shop continusly tank an old refridgeator. jump the light switch but in a 50 wat bulb and it will keep freezable items from frezzing.
just a thought |
02-05-2014, 10:43 AM | #13 |
Re: shop heat
This coming fall I'm planning on sectioning off a small area of my detached garage to make a 9x18 heated area for my Model A. I've been wondering about the same thing, how to heat it. I don't want it heated 24/7, just heated when I want to work out there. The problem I see with small open flame heating systems is that the water vapor created by the heater with condense on anything still cold in the room. Is there a small propane heating system that is similar to a hot air furnace where there is an exhaust for the water vapor.
AL in NY |
02-05-2014, 12:30 PM | #14 |
Re: shop heat
That is a sweet looking shop! Could sure use some of that heat here in OKC this morning. 5 degrees when I got up.
Oklahoma City Model A Restorers Group. |
02-05-2014, 10:41 AM | #15 |
Re: shop heat
I have a small diesel Salamander I got from Home Depot/ Lowes for less than $100. I have a 40X40 shop with 10 foot height, no insulation. I start it about an hour before I go to the shop. I am usually very comfortable. If I run it a lot it will use 2-3 gallons of diesel a day. Another nice thing (rather than wood) when I leave the shop, the fire is out.
02-05-2014, 10:49 AM | #16 |
Re: shop heat
"Have a well insulated shop with central heat and air, uses natural gas. I never turn the heat off in the winter, I just turn it down when I am not in the shop."
Ditto. I use a high fan to blow the heat to the floor. Main shop is 30x30. Other areas are car and parts storage Back east I used a waste oil burner I made and got used motor oil, used cooking oil, etc from any place I could "The problem I see with small open flame heating systems is that the water vapor created by the heater with condense on anything still cold in the room." This is a very real issue that must be dealt with
'31 180A |
02-05-2014, 10:58 AM | #17 |
Re: shop heat
Old gas fired forced air furnace in shop/barn with sectioned off partitions/rooms. Only used when needed.
02-05-2014, 11:31 AM | #18 |
Re: shop heat
I do most of my own A work in my cellar.I mostly heat the house with wood,and the stove is down there.Once the concrete is warm it is just a matter of keeping it warm for the winter.I've been down with the flu,and didn't have the energy to haul wood in,so I let the oil take over.The stove was out for 3 days and I restarted it a couple of days ago.It has been cooking away,and is taking a long time to warm the concrete up again.I heat my shop with waste oil,I bought a new commercial unit in 1986 that works pretty good.Those units were built with oil disposal in mind,not economy.The more they burned the better off the garages were.Oil is getting harder to come by now though.I have always had oil generated by trucks but things have changed.Just one guy here changed his oil at 10,000 miles.He runs about 150,000 a year,and his truck with filters holds 15 gallons.That was always 225 gallons for me and the furnace.His new truck holds seven gallons,and gets changed at 50,000 miles.Now I get 21 gallons and it is synthetic to boot.The furnace doesn't like synthetic.The computers have those trucks running so clean now the oil never soots up.
02-05-2014, 11:54 AM | #19 |
Re: shop heat
I've got my 40x98 shop very well insulated (R-65 in the ceiling) and real tight. It's kept at 50 degrees all the time with a propane furnace, but when I'm around I keep a wood furnace going, and that works real well. But the 3 overhead doors were a real problem leaking around the frame. I found some spring loaded hinges that completely solved that problem,so the shop is cheap to heat and always warm. If you let the temps. go up and down below freezing then there will be condensation issues. No good.
02-05-2014, 07:43 PM | #20 |
Re: shop heat
I HAVE A 14X26 ROOM AT THE BACK END OF MY GARAGE. USE AN OIL FIRED HOT AIR TRAILER FURNACE FROM A MOBIL HOME. SET THE THERO AT 60 DEGREES. TURN IT ON ABOUT AN HOUR BEFORE I GO OUT. WORKS GREAT. I DO USE KEROSCENE AS # 2 OIL STARTS HARD IN OUR LOUSY COLD WEATHER.
MY PROBLEM CHILD! |
