Old 07-25-2020, 11:49 PM   #21
DMMuir
Default Re: Newbie to forum, and Ford.
JSeery, how many NOS parts can there be on an 80 year old car??? They gotta run out some time.
DMMuir is offline   Reply With Quote
Old 07-26-2020, 01:47 AM   #22
ford38v8
ford38v8's Avatar
Here's something about NOS parts that many have found out the hard way:
What's referred to as NOS is sometimes technically incorrect, although the part may never have been installed on a car, they may have come very close, but were rejected at the assembly line. Parts that have remained unsold all these years are all suspect for this reason, or have been damaged in some way over the ensuing years. These parts today are better as seconds than any modern repro could ever hope to be, but just so you know, some will require a massage to make it fit.
Alan
Old 07-26-2020, 02:45 AM   #23
V8COOPMAN
V8COOPMAN's Avatar
@V8Coopman They did come from a Florida M place. And they are completely the wrong part. I'll go check in on the other ones and see if I can get them there
DMMuir…….Glad you found out before things turned 'south'. PM one of our 'regular posters' that goes by "barnfind08". His name is Fred Wilmer and owns "Southside Obsolete". He has warehouses full of NOS Ford parts, and he's a good guy. As of this past January, he had the correct Ford axle nuts in stock...NOS...the REAL deal. You can send him a PM (private message) directly by clicking on the link I've arranged for you below. Your best bet going! DD
https://www.fordbarn.com/forum/priva...do=newpm&u=104
Click Links Below __
T5 W/TORQUE TUBE
Old 07-26-2020, 07:38 AM   #24
JSeery
JSeery's Avatar
Not everything is available NOS, but a lot is. IMO it is always best to check for them first. The next best option is to check with suppliers that provide high quality parts and advice AND stand behind their parts. And yet another option is to have your existing part refurbished. The Barn is a great source for information on where to go for different parts and services. Your axle nuts are a great example, a lot of what is available from some suppliers are not usable. Oh, and there is always used parts.
Old 07-26-2020, 07:43 AM   #25
JSeery
JSeery's Avatar
To added to this, while NOS is often the best way to go, that is not always the case. Some parts degrade on the shelf. A good examples are some electrical parts like capacitors, coils, etc.
Old 07-26-2020, 12:19 PM   #26
grumppyoldman
grumppyoldman's Avatar
welcome to the Ford Barn DM, these guy's have helped me many times. you have come to the right place. Al
grumppyoldman is offline   Reply With Quote
Old 07-26-2020, 10:54 PM   #27
40 Deluxe
Unless damaged (like having been removed with a pipe wrench) the original axle nuts will be just fine.
Just draining out the old gas may not be enough. When a car sits long enough for the gas to evaporate out of the tank a varnish-like residue is left. Fresh gas (especially ethanol blends) will dissolve this residue.
When this stuff is burned in the cylinders, it leaves a goo on the exhaust valve stems that causes the valves to stick. Sometimes the only cure is to remove the valves to clean. You'd be ahead to drop the gas tank and get it boiled out at a radiator shop.
40 Deluxe is online now   Reply With Quote
