06-03-2017, 03:02 AM | #1 |
6V brake light for rear window - $5.14
I bought a couple rear window brake lights from Amazon for $5.14 as I've been looking for a while and these were in a housing which fits my application ('50 Merc). While they are NOT Amazon Prime shipping but free shipping none the less. I say $5.14 all in is stupid cheap. After about a 10 day shipping time, they arrived and I got out the tools. I discovered the plastic housing comes apart easily. I feared it was glued together as it appears but not so. The plastic cover just snaps onto the housing. I admit I really bought them for a housing to play with but my next amazement - they light up nicely on 6 volts although not as bright as on 12v. And I do want bright for daytime use. Digging further I find the guts are suited to experimentation as is. The leds and their 1k dropping resistor are surface mounted (SMD) on a narrow pc board which comes off with a couple of tiny screws. AND I was able to parallel the existing 1k ohm voltage dropping/current limiting resistor with another standard 1k resistor and regain the brightness of 12v using only 6 volts! I don't yet know if that will be satisfactory for daytime shock value (I worry about getting 'texted' in the rear by a teen cell addict. I may get some super bright LEDs to play with. Which is one reason I bought 2 of these things to start with. The NNDA company has many leds available but I don't believe the 5 leds used in this housing to be of the 'super bright' variety. If you are interested in stupid cheap, search Amazon for "NNDA CO 12v Car 5 LED". I can take pictures of the guts if there is a need or interest, otherwise I will let the subject drop with this heads up notification. |
06-03-2017, 07:22 AM | #2 |
Re: 6V brake light for rear window - $5.14
The other reality of stupid cheap LEDs, beside basic brightness, is that they tend to fade (lumen depreciation) or fail after limited use. Big difference between novelty item and automotive use quality.
If you are just in it for giggles, please proceed.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
06-03-2017, 08:20 AM | #3 | |
06-03-2017, 08:27 PM | #4 |
A 3rd light connects directly to the brake light pressure switch prior to turn signal wiring. It wouldn't be a bad idea to add an additional mechanical brake switch instead of using the hydraulic pressure switch. In this way the 3rd light would come on several tenths of a second before the tail lights AND you could even ride the brake to light it up without energizing the brakes when someone is following too closely behind you.
06-04-2017, 03:33 AM | #5 | |
Also I am using a mechanical switch which as you say, does away with any hydraulic issues.
06-04-2017, 06:28 AM | #6 |
06-04-2017, 07:42 AM | #7 |
Paul: Never heard of Occam's razor.
Learned something new, thanks to you. |
