Old 01-09-2013, 12:37 PM   #1
duffer
duffer's Avatar
Default sediment bowl question
Just got a new neoprene gasket and screen for my glass sediment bowl. Does the screen go to the glass side or to the top? i'm asking because Mikes catalog says gasket , screen , glass and Bratton's says screen ,gasket ,then glass. There was no screen when i took it off. Thanks
duffer is offline   Reply With Quote
Old 01-09-2013, 12:49 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: sediment bowl question
Screen on top, then the gasket next to the glass.
Old 01-09-2013, 12:54 PM   #3
davehc
davehc's Avatar
The way I did mine was , put the screen up into the recessed area in the top then the gasket , then the bowl , with the bale holding in place . Worked for me .
davehc is offline   Reply With Quote
Old 01-09-2013, 01:45 PM   #4
ken ct
I put the screen in first then the gasket,I would lose the rubber one and use a good cork one. OMO. ken ct.
ken ct is offline   Reply With Quote
Old 01-09-2013, 03:20 PM   #5
duffer
duffer's Avatar
ok thanks guys...
Old 01-09-2013, 03:42 PM   #6
Fred K-OR
Fred K-OR's Avatar
I agree with the cork gashet. The other one will expand and it will not fit once it gets gas (crapgas) on it.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 01-09-2013, 03:50 PM   #7
Mitch//pa
Cork here also
Old 01-09-2013, 09:05 PM   #8
Tom Wesenberg
Absolutely. Cork only.
Old 01-10-2013, 10:56 AM   #9
Jerry Parr WI
Jerry Parr WI's Avatar
The screen fits into a recessed area in the housing. The cork gasket goes in next and is wide enough to hold the screen in place. Is the neoprene gasket wide enough to do that?
Jerry Parr WI is offline   Reply With Quote
Old 01-10-2013, 11:22 AM   #10
ba49
I agree with the cork gasket. The neopreme ones are only good for one use and they swell up. I make my own with a sheet of cork gasket material and cut it out using two different sizes of exhaust pipe shapened on the end. I use them like a cookie cutter, works great.
ba49 is offline   Reply With Quote
Old 01-10-2013, 08:24 PM   #11
Steam Engine Pete
Steam Engine Pete's Avatar
I agree with the order of screen, gasket and then bowl but disagree with the cork gasket. I used to be a cork gasket fan because the neoprene always swelled up. I have found that the bowl gaskets that NAPA sells do not swell up. I assume they are neoprene but I really don't know what they are mad of. They are a black, rubber like material but they do not swell up like others I have used. I always have them on hand now and refuse to put in anything else when working on a fuel bowl. Just my two cents.
Thanks,
Pete
Steam Engine Pete is offline   Reply With Quote
Old 01-11-2013, 09:15 AM   #12
Richard Wilson
Richard Wilson's Avatar
I agree 100% about the rubber gasket NOT being the best choice! Yesterday, I was in the basement and thought that I would do a little fine tuning on one of my Model A's that had been parked for about 6 months. I had installed a brand new repro rubber gasket in the sediment bowl just before parking the A.
First thing I noticed when I raised the hood was that the glass bowl was only 3/4 full of gas. The gas looked like black paint. When I removed the glass bowl to clean out the old gas the rubber gasket puffed out and looked like a black marshmallow. I replaced the swollen/dissolved rubber gasket with a cork version that I had in my traveling parts kit. I think some of the Model A guys will have a big surprise when they try to get their Model A's and other old cars with rubber fuel line parts out of storage in the spring.
Richard Wilson is offline   Reply With Quote
