Old 06-03-2023, 06:33 AM   #1
sawzall
sawzall's Avatar
Default bought a 32 ford.. need to adjust the clutch
photo for attention..
because I will not be able to get a good photo down inside the transmission inspection cover!
I bought this 32 ford a few weeks ago. prior owner rebuilt engine / trans but never drove the car.
I had to adjust the clutch rod all the way out in order to move the car from the trailer to my garage and up and down my driveway a few times.
however I kit seem (after driving it a few 100 yards) that the clutch may need adjustment.. as the pedal must be pushed all the way to the floor to get any engaugement.
looking in the inspection cover the throwout bearing (with out pressing on the pedal) is approx 1 inch from the clutch fingers.. it is obvious that the individual fingers could be adjusted up ALOT however before I go through that proceedure.. is there anything else to consider?
Pennsylvania has two seasons. Hershey week, and everything else https://sites.google.com/site/eastcoastwoodies/
sawzall is offline   Reply With Quote
Old 06-03-2023, 08:54 AM   #2
DavidG
DavidG's Avatar
Default Re: bought a 32 ford.. need to adjust the clutch
Your description suggests that the previous owner did not adjust the clutch when it was installed. Now you get to do it. Unfortunately with a '32, that means pulling the engine and transmission together and that means removing the radiator, radiator shell and headlamp bar for starters.
Old 06-03-2023, 10:43 AM   #3
V8COOPMAN
V8COOPMAN's Avatar
Sounds almost like it has a short throw out bearing in it.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 06-03-2023, 01:45 PM   #4
sawzall
sawzall's Avatar
What's a short throw out bearing??
Old 06-03-2023, 02:59 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
You obviously haven't fooled with older GM stuff. There were LONG & SHORT T/O bearings, with the longs being about an inch or so thicker (front to back). I guess Fords never got that complicated. Here's an example in the picture BELOW.
Coop
T5 W/TORQUE TUBE
Old 06-03-2023, 03:20 PM   #6
cadillac512
cadillac512's Avatar
When looking through the inspection cover and foot off the clutch, is the fork and bearing pulled all the way back (or nearly) against the transmission? (the small return spring will be almost unstretched). If so, that's not the normal adjustment range. Maybe a shorter clutch rod was installed or some other linkage problem is present. Would lengthening the adjustment rod cure the problem?
The three fingers on the pressure plate will be almost flat... just a touch toward the transmission....when they are not touching the bearing. If so, a longer rod may fix this problem.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-03-2023, 03:29 PM   #7
Will Kimble
Stock pedals? Stock ‘32 clutch arm?
Will Kimble is offline   Reply With Quote
Old 06-03-2023, 07:47 PM   #8
sawzall
sawzall's Avatar
Stock pedals stock clutch mech..
Old 06-03-2023, 08:35 PM   #9
sawzall
sawzall's Avatar
Old 06-03-2023, 08:44 PM   #10
sawzall
sawzall's Avatar
Stock pedals..
Old 06-04-2023, 10:29 AM   #11
glennpm
glennpm's Avatar
From VanPelt's site, http://www.vanpeltsales.com/FH_web/F...32-34_65hp.jpg
Glenn
Old 06-04-2023, 11:51 AM   #12
kurt v
broken pin on through out bearing fork ?
kurt v is offline   Reply With Quote
Old 06-04-2023, 12:24 PM   #13
sawzall
sawzall's Avatar
Maybe.. thanks for that thought!..
Old 06-04-2023, 01:03 PM   #14
kurt v
dang old age can't spell anymore
Old 06-04-2023, 01:29 PM   #15
DavidG
DavidG's Avatar
Not likely a broken pin in the fork given that he drove it a couple of hundred yards.
