02-19-2024, 07:26 PM | #1 |
What the heck just happened ? (electrical)
So I’ve always been interested in test equipment, especially simple things like test lights but never went to the trouble of buying one. Anyhow I’m on Amazon and see a cheapo test light that has a built in readout that shows voltage so I buy it. It arrives and I’m eager to try it (even though nothing is currently broken). I pop open the drivers side hood and connect the ground to a head bolt and then the probe to the starter terminal. It lights up and reads 6.5v, nice. I then think, hmm what else can I try…. So I stick the probe on the cutout output terminal. Instantly it sparks, welds itself to the terminal nut and I’ve blown my 30a starter fuse….
What the heck? Any idea why this happened?
1931 Slant Windshield fordor |
02-19-2024, 07:51 PM | #2 |
Re: What the heck just happened ? (electrical)
You bought a welder? Is your car + to ground?
02-19-2024, 07:56 PM | #3 |
Yes sir, positive ground. What i dont understand is why it happened on the cutout output terminal, but everything was fine when i hooked up the main starter terminal. Just wondering if that spot is a general no-no for some reason.
02-19-2024, 08:16 PM | #4 | |
Is it possible your test light has a "amps" or "current" setting and it accidentally got switched to that?
2024 MAFCA Technical Director |
02-19-2024, 08:33 PM | #5 |
Thank you for the response, your hypothesis could certainly be true. I've had my A for 12 years now and I've probably used my fluke at the cutout terminal dozens of times without issue. I'm guessing this 20 dollar amazon test light must be junk, after the incident the unit is totally dead. Swapped out the fuse and the car is happy as can be. Letting you all know to avoid this item:
"Heavy Duty 3-65V Backlit Digital LCD Circuit Tester, Test Light with 140 Inch Extended Spring Wire, Car Truck Low Voltage & Light Tester with Stainless Probe"
02-19-2024, 08:49 PM | #6 |
02-19-2024, 09:09 PM | #7 |
The other thing that may be a possibility, could you have touched both the terminal AND the case of the cutout?
02-19-2024, 09:09 PM | #8 |
Strange. It says you can hook the alligator clip to either POS or NEG.
02-20-2024, 08:08 AM | #9 |
Either you accidentally touched ground while probing the cutout terminal or there is a short in the circuit tester. Does the circuit tester still work? You could test for resistance of the circuit using the ohm setting on your Fluke. If very little resistance, it is shorted. That way you don't have to chance another welding experience.
02-20-2024, 08:56 AM | #10 |
It appears that the probe provided a connection of the battery to the generator, so the generator acting like a stalled motor, drew a large current to it.
Bob Bidonde |
02-20-2024, 10:11 AM | #11 |
I think eagle hit the answer. You could test the test light by using a battery like a 9V or AA and see if it works. The bulb and circuitry inside the tester would not allow that much current to flow and allow the welding of the probe.
02-20-2024, 12:50 PM | #12 | |
(Cheap Chinese Crap) Although $20 is not so cheap.
02-20-2024, 05:15 PM | #13 |
Unfortunately the unit is totally dead, no further testing on it possible. I'll probably stick with the tried and true units that have just a bulb in them.
02-20-2024, 05:38 PM | #14 |
I'd send it back to Amazon for a refund as defective.
02-20-2024, 07:39 PM | #15 |
Amen! Ernie in Arizona
02-22-2024, 09:51 AM | #16 |
"CCC" Probably came from Ali-Baba over in the nether-regions!
--------------------------------------- 1929 Model A Tudor "Stay away from negative people, they have a problem for every solution" Model A Ford Club of America Model A Restorers Club Motor City A's Club |
02-22-2024, 10:31 AM | #17 |
Why does it seem like everything made in China has QC problems?
02-22-2024, 11:21 AM | #18 |
I agree. Not to pile on here but if the car is positive ground your first connection of ground clamp to head bolt was reverse polarity and electronics usually if not always turn up their toes on that one.
