Old 01-25-2022, 12:25 PM   #1
dewert
dewert's Avatar
Default 1940 for turn light bulbs 12 volt
Working on 40 van headlights. 12 volt light bulbs for parking/turning light bulbs. It appears that the bulbs socket is set up for "straight across" notches. All I can find is off set notches for this bulb. Do I need to change sockets or where can I buy the straight across notched bulb. Kind of slow but I am tring. Thanks, David
dewert is offline   Reply With Quote
Old 01-25-2022, 01:22 PM   #2
Mart
Mart's Avatar
Default Re: 1940 for turn light bulbs 12 volt
If you are using the parking light sockets for the turn signals only there are small bulbs available for mini bikes. They are 23W, orange and have straight across pins.
I used these on my 41 pickup.
I used replacement headlamp units with side lights (parking lights) built in.
I did a video on it.
https://youtu.be/wBlORE5fXdI
Mart.
Old 01-25-2022, 01:35 PM   #3
dewert
dewert's Avatar
Mart.
thanks for the info. looks like my bulbs are a lot bigger. not sure if they put in the sockets or used the originals. Good info and i will keep working on it.
Old 01-25-2022, 01:50 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
The dual filament, 12v brake/tail light bulbs that you want with STRAIGHT-ACROSS pins are 1176 bulbs. That socket with the STRAIGHT-ACROSS pins is called a "BA15D" socket (NOT a BAY15D).
DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-25-2022, 02:20 PM   #5
dewert
dewert's Avatar
thank you, thank you, thank you.
Old 01-25-2022, 02:21 PM   #6
dewert
dewert's Avatar
thank you 100 times
Old 01-25-2022, 03:44 PM   #7
cas3
When I do that sort of conversion, I change the sockets to the offset pins. Reason is, those sockets also have a guide for the fiber wire base so it can not move when you twist the bulb in place. If you google "bulb sockets", you will find Industrial outfits with thousands of choices to see what will work out best for your application
Old 01-25-2022, 03:55 PM   #8
ssffnomad
ssffnomad's Avatar
#1157 offset pins sockets
Amazon, “Bayonet Bulb Socket”.
BAY 15d base .
$2.99 each
ssffnomad is offline   Reply With Quote
Old 01-26-2022, 08:20 AM   #9
dewert
dewert's Avatar
BAY 15d base .
$2.99 each
Thanks for the info. Now I will have to rethink what I am doing.
