06-01-2014, 03:46 PM | #1 |
steering column tube ,changing from bushing upper bearing
I want to replace my steering tube upper bushing to a bearing ,I cant find the records on the search feature here on the barn, I had it all written down and can't locate my notes on the swap. will someone please post the info. again? as I remember there was a hardware store replacement bearing number and brand name. it is a 46 ford steering tube.
Thanks! Fordestes Last edited by Fordestes; 06-01-2014 at 03:49 PM. Reason: more info . |
06-01-2014, 04:11 PM | #2 |
Re: steering column tube ,changing from bushing upper bearing
06-01-2014, 04:15 PM | #3 | |
http://www.fordbarn.com/forum/showth...column+bearing Getting Henrys old bushing out of the top of the column tube can be a challenge. I have had some that I had to remove the column tube and go in the tube from the steering box end with a piece of pipe and drive the old bushing out. One column tube had three bushings, one on top of the other. I guess the po's just kept driving new bushings in on top of the old because that was easier than removing the old bushing.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 06-01-2014 at 09:08 PM. |
06-01-2014, 05:09 PM | #4 |
That's one way of doing it, driving the old ones deeper, I bought a replacement bushing for a 36 column and when I put it in it fell down the column , obviously a poor copy, so I just put the original Ford one back in. I was only replacing it because I had the column apart.
06-01-2014, 11:05 PM | #5 |
I just happened to see this online. does it help?
http://www.ebay.com/itm/1932-1933-19...27aa41&vxp=mtr
John Live for today, but save for tomorrow! |
06-02-2014, 09:38 AM | #6 |
Fordestes, |
06-02-2014, 01:28 PM | #7 |
I've used a gokart wheel bearing. Bearing house item to fit id of column but with a flange.
06-02-2014, 01:28 PM | #8 | |
06-02-2014, 02:33 PM | #9 |
I've always used the ones from Ford. I don't think thsy still have them , but C and G Parts carry them and they work well.
06-02-2014, 07:18 PM | #10 |
2 possible sources;
The post I read a ways back for '40 Ford, gave a McMaster Carr part #8258K22. Described as a double sealed, grooved, precision steel needle roller bearing for 3/4 diameter shaft. $18.41 a ways back. If you are looking for an NOS one, check with Fred at So Side, or Ron at Dennis Carpenter NOS. |
06-03-2014, 05:44 AM | #11 |
Thanks Russcc, That bearing sonds like it is a lot heavier duty and the price isn't bad either.
Fordestes, |
06-03-2014, 07:16 PM | #12 |
With the exception of fastners, I believe most McMC products are also made in the USA. They usually can't give you the actual Mfg name, but they are mostly USA products. I ordered a 7/16 flare fitting crows foot, it was very reasonable, and when I got it was Snap-On USA. Can't beat that.
06-03-2014, 08:09 PM | #13 |
Yes m/m has a good product lie , I had them as major supplier in my truck repair shop, I forgot they do sell other supplie besides nut and bolts, the quality is unsurpassed and service cant be beat ,such as next day!
Thanks all, I didnt realize there were so many options , thats why I asked here I knew I would get sound advice. Fordestes, |
