Old 02-25-2019, 05:46 PM   #1
Colonel
Default Door Fit Problem
Raised the front of the body a bit to better align the hood. Added a couple rubber shims on each side. Hood is great.
Both doors(coupe) worked well before I did this. The passenger still works well but the driver door seems high on the hinge end and low on the latch end. The door will close when I lift it a bit and close it with force. I suspect I did this misalignment when I shimmed the front of the body. Looking at the latch, the door is a good quarter in above where it was before.
I would like to keep my front body shims in place but maybe not. I would prefer to adjust the door a bit. Any suggestions on best way forward? Thanks.
Colonel is offline   Reply With Quote
Old 02-25-2019, 06:15 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Door Fit Problem
work back and add shims---or has the frame been checked,
