02-14-2022, 08:11 AM | #1 |
Jump 6 volt system with 12 volt portable jumper
Is there a 12 to 6 volt reducer that can handle the amps of a portable 12 volt jumper. Jumping with a 12 volts will blow the gauges and and motors. I am buying a 54 Ford automatic and there is no pushing this car to pop start it.
02-14-2022, 08:29 AM | #2 |
Re: Jump 6 volt system with 12 volt portable jumper
You can use 12 volts but just for the starter. To run the car a 6 volt is necessary. You must hook the 12 volt directly to starter.
02-14-2022, 10:13 AM | #3 |
https://www.youtube.com/user/roosty6/videos |
