Old 08-25-2020, 11:36 AM   #21
stillwater
Default Re: Found On Road Dead
Originally Posted by Will D View Post
Glad you got 'er figured. Now instead of Found On Road Dead you can be First On Race Day.
Right!
And, he won't get passed by no "F.n Old Rebuilt Dodge" either.
stillwater is offline   Reply With Quote
Old 08-25-2020, 12:11 PM   #22
GB SISSON
GB SISSON's Avatar
If you can insulate a rotor against the spark of a T coil, it should be good for anything. Speaking of which, I have been scheming about how to avoid the shorted rotor syndrome in the future. Plastic or rubber disc, epoxied in the center of rotor under the tab? I realize if it's too thick the cap would be too tight. Thinking I'll put a blob of clay with a waxed paper lid under the spring steel tab and see whar it measures, then go to something thinner. I have some flex-tape (as seen on tv) and man is it sticky. Maybe just a disc of that after cleaning rotor with laquer thinner. Of course I'm probably just over-thinking this. Again.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 08-25-2020, 01:49 PM   #23
Mart
Mart's Avatar
Having had a rotor fail straight through the top part under the tab, I "bullet proofed" my next new ones with a blob of epoxy over the center of the top. They've worked well since.
Old 08-25-2020, 03:03 PM   #24
GB SISSON
GB SISSON's Avatar
Mart, you are my kinda guy!
Old 09-07-2020, 08:10 PM   #25
GB SISSON
GB SISSON's Avatar
Well as some of you had read, this isn't the last of it..... BUT, this morning I fired it up and it was clearly running on seven cylinders. Turns out #1 was not firing. No spark at all off plug wire. Tried a different wire, good blue spark. I found a set of copper core 'cut to fit' wires so I made a new one for #1. No more miss. But I did notice the bad wire was a fuzzy core modern wire. (it wouldn't spark at all). That's odd , I would never buy those resistor wires for old school ignition. Then I had a pretty clear recollection that the woodie's plug wires came from a donor engine. They were off some filthy mess I dragged home but I liked the red plug boots and they all matched and were already the right length. I cleaned them with laquer thinner and they looked great on the refreshed 221 I built for the woodie. BUT..,. They were old and not real wire. I'm just hoping when I take it for a test drive in the morning, it was the wires all along that were a big part of the problem , along with the shorting rotor.
Old 09-07-2020, 09:50 PM   #26
cadillac512
cadillac512's Avatar
GB, those high resistance carbon core wires may have been what caused the spark to jump through that rotor. Path of least resistance and all you know...
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 09-07-2020, 10:00 PM   #27
GB SISSON
GB SISSON's Avatar
Terry
Thanks for that, never thought about that resistance. The plot thickens...
Old 09-08-2020, 01:57 AM   #28
Lawrie
Lawrie's Avatar
RKS, I’m away from my home for a couple of weeks so remind me then ( PM me) and I will shoot you the info.
Lawrie
Lawrie is offline   Reply With Quote
Old 09-08-2020, 12:12 PM   #29
RKS.PA
RKS.PA's Avatar
Gary, had absolutely the same experience! Rotor, Cap, and Bubba dist. all checked out, but couldn't get rid of intermittent miss. Changed my "lovely" Belden blue carbon cores for solid copper....Voila....or maybe Viola!!!....no more miss. Lot's of wasted hours chasing this. Also, I have an original Ford/Philco radio, so thought I might get interference with the solid copper.....nothing!!
Best of luck with all your projects!!.....Dick.
RKS.PA is offline   Reply With Quote
Old 09-08-2020, 12:14 PM   #30
RKS.PA
RKS.PA's Avatar
Lawrie
Thank you, Lawrie. PM sent.
Old 09-08-2020, 05:36 PM   #31
GB SISSON
GB SISSON's Avatar
Yessiree Dick! That was it! Just did the run to town (which is uphill both ways) and she pulled like a flathead V8! Not one stumble, not one miss. Coming home up the long grade where it ran the worst this summer, I used to have to downshift half way up, but roared over the top in High. Well, I woulda roared, but some pokey tourist was creeping along in front of me. I rode his tail but I refused to downshift. I still topped the hill easily in high. Now I wanna go on a road trip, but alas, half the state is on fire and probably not the best idea when your car is made out of wood! Thanks once more to all of you for the help!
Old 09-08-2020, 05:51 PM   #32
mike in tucson
My typical fail is to put the bad rotor back into my box of electrical stuff so I can pull it out again in the future and go thru the entire sequence again. Kinda like my wife's dad had a keyboard that had an inoperative key....I took him a brand new one and he saved the old one for a spare!!
mike in tucson is offline   Reply With Quote
Old 09-08-2020, 06:46 PM   #33
GB SISSON
GB SISSON's Avatar
So completely LOL. I took the old rotor and tossed it into a trash can beside the shop to stifle the urge. Well the following saturday we were going to the dump and after loading the cans into the pickup I found that old rotor sitting on the ground. I had missed the shot. For a brief moment I thought about sticking it in my pocket just because... And my spare laptop has 5 inop keys and a separate add-on keyboard with a cable that makes a connection sometimes. My daughter bought me this one. You musta read my mail!
Old 09-08-2020, 07:09 PM   #34
flatford8
flatford8's Avatar
“Now I wanna go on a road trip, but alas, half the state is on fire and probably not the best idea when your car is made out of wood! ”
Ya....I can see a problem there!!!......glad your back running on all eight!!!.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 09-08-2020, 09:38 PM   #35
tubman
tubman's Avatar
"The Brillman Company" has Packard 440 wire available in several different amounts. It is all I will use on these old cars.
