02-05-2016, 03:00 AM | #1 |
semi finish bearings / resizeable bearings / full floater
Hello Guys,
since i have a rod bearing damage and figured out my crank was allready grinded 0,030 under i bought a set of semi finish full floater bearings / resizeable bearings. Has anbody of you anytime cut / bored those bearings to size and can give me advice how to get them fit? thanks all Ingo |
02-05-2016, 03:25 AM | #2 |
Re: semi finish bearings / resizeable bearings / full floater
Look up Walt on here, pretty sure he's had a lot of experience with these semi finished bearings.
Martin. |
02-05-2016, 04:03 AM | #3 |
ha thats funny, Walt was it who recommend to post my question here in the barn. As i understand him he used those bearings back in the 60s but he gave it to a machineshop to cut them to size. So he personally doesnŽt know how to do it...
02-05-2016, 04:22 AM | #4 |
Semi finished just means the bearing is maximum undersize with a bearing material thicknes enough to resize it to less undersize.
On a fixed bearing its just to install it in a rod and hone. On a full floater you need a fixture to hold it tight making sure its round before sizing. |
02-05-2016, 07:06 AM | #5 | |
02-05-2016, 08:15 AM | #6 |
02-05-2016, 09:55 AM | #7 |
Look up Tobin Arp bearing resizer on Google and you will see the way it is done.
02-05-2016, 11:18 AM | #8 |
The Tobin machine is essentially a 'line bore machine' for bearing shells and/or caps. If you can find somebody who has one and knows how to use it, then this would be a good approach. I believe you could make a one-off custom holder that would work in a lathe - specifically for the full-floater 91A/21A bearings you have. If you want me to draw you up a 'fixture' - and then you could have it made, ping me off line. There are guys with the Tobin machines - you should be able to just send them your bearings and the crankshaft dimensions . . . if you can find "that guy". Good luck
02-12-2016, 07:34 AM | #9 | |
Thank you Ingo |
02-05-2016, 11:25 AM | #10 |
Making a fixture for the floaters, getting machine work done etc. seems to me would cost a whole lot more then just getting a good crank that is ground to the size of the good throws and getting 1 pair of new shells for throw that was damaged. Or even having the 1 throw welded up and ground back to the size of the rest.
02-05-2016, 01:30 PM | #11 |
Yes, I have some suggestions after having performed this operation several times---the OD of the bearing shell should be clamped such that it is perfectly round and matches the diameter desired to fit the rod housing. Just boring a sleeve to be a tight fit on 2 bearing shells will not do it correctly as the gap between the 2 shells will likely cause the sleeve bore to differ from the rod housing and getting the bearing shells to perfectly conform to the sleeve bore will be a challenge. But, if the shells are not tight in the sleeve, all around the outer perimeter, the shells will have thick-thin conditions when re-bored.
I did one set in a lathe where I tapped the oil holes and screwed the shells to a bored sleeve. My results were just "ok". Your results might vary. |
02-05-2016, 08:01 PM | #12 |
JWL has a good point. Maybe a good approach would be to create the fixture and then use some .001 or so shim stock all around the outside of the bearing - to simulate oil and clearance. I'm just talking out loud. If it was me, I'd find a replacement 59x or 8BA crankshaft and not screw with it (but he already knows that part from me! LOL)
02-06-2016, 07:34 AM | #13 |
Tanks guys for your tips, iŽll try and Keep you posted
Ingo |
02-09-2016, 06:52 AM | #14 |
What year engine are you working on? I have a pair of flanged .040 under bearings I don't need.
02-12-2016, 07:31 AM | #15 |
02-09-2016, 08:46 AM | #16 |
I dug out this Sunnen bearing sizer, it has a proper sized insert holder, I have the instructions, a few pieces of tooling are missing but not hard to make, it was all stuck not moving with congealed oil I got it freed up some but it needs to be taken apart to free up the feed
02-09-2016, 08:48 AM | #17 |
The phone only loads one picture
It uses the sunnen machine to adjust the cutter, looks to be somewhat trial--error to get size, the instructions say to take a cut and measure, each graduation on the machine dial is about .001----seems like it would take some practice to be consistant---it does look like the insert can be removed without changing the setup so once the inserts were close the final cut could be repeated by just changing the insert, no change in cutter depth Last edited by Kurt in NJ; 02-09-2016 at 09:00 AM. |
02-09-2016, 09:23 AM | #18 |
Thats a nice little attachement.
Big i want one factor...another one to the list of stuff to find. |
02-13-2016, 05:52 PM | #19 |
Okay Ingo - I'm working in CAD this evening, will send it your way . . . both the 3D CAD model as well as a 2D drawing.
02-14-2016, 01:30 PM | #20 |
Here is a screenshot of the bearing holder - designed it in SolidWorks. I'd make it out of 6061 Aluminum. It needs to be dead-nuts correct in the inner bore - so the bearings sort of 'press in' by hand. The depth of the pocket leaves about .005 of the bearing sticking out - so the top plate can be used to hold them down and in position.
I made four 'relief' holes (1/2") that go all the way through the main part - so that one can use a wooden dowel rod or something soft in case they need to "tap" the bearings back out after the machine operations (from behind). I usually forget crap like this - than wish that I didn't! Can't say that I've ever attempted to 'bore bearings' on a lathe, but there is no reason it can't work if the machine is good and the operator knows how to do precision work. If anybody wants a copy of the CAD model, just ping me . . . not a big deal by any means. B&S 2-14-2016 1-26-16 PM.jpg Last edited by Bored&Stroked; 02-14-2016 at 04:30 PM. |
