Old 01-19-2022, 12:09 PM   #21
Karl Wescott
Karl Wescott's Avatar
Default Re: 3D Printing an Overdrive Knob
Originally Posted by Eagle43 View Post
I pretty much agree. 3D printing is just another tool in the tool box. I would basically use it to duplicate parts that are already plastic of some sort like bakelite. As to it being slow - that is true but not a big problem. The knob takes about an hour to print but I just get it started and leave it and do something else. Earlier last summer I made my second version of a CNC Router/Laser with mostly printed parts. Some of the pieces took up to 17 hours to print so I just ran the machine basically 24/7 and used up almost 3 Kg of filament until it was done.
Regarding your pictures, I'm wondering if these are printed items. I have done some investment casting in aluminum but have not tried the "Lost PLA" investment casting which allows you to print a part in PLA and cast it in metal.
I have used pla as an investment with both good and poor results. Visible layers tend to be magnified during the investment process, and the difficulty of getting a fine surface on the down side where there are support layers limits the process. Best results happen with a pure pla, minimum infill, with no fillers or pigments that may be difficult to burn out when firing the ceramic shell. On the up side a pla investment is a lot stronger and tends not to break in oopsies that shatter a wax investment. Overall I have found molding the wax to be more efficient for me at this time. I have also seen where actual wax is 3d printed, though I understand it is difficult due to the wax filament being brittle and a relatively low melt structure.
Karl Wescott is offline   Reply With Quote
Old 01-19-2022, 01:32 PM   #22
itslow
itslow's Avatar
Originally Posted by Karl Wescott View Post
Metals with any structural value simply are not happening, except for some aluminum requiring a 10+K printer.
Not happening at the hobbyist level, but can/does happen at the industrial level since the equipment to build such parts is incredibly expensive (six figures).
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 01-19-2022, 01:34 PM   #23
kirkf
kirkf's Avatar
3D Printing is available as a service in almost every city. That gives you access to the top level equipment without buying it.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 01-19-2022, 02:00 PM   #24
pistonbroke
Very nice Job on the OD knob. I'm curious about your choice of transmission. I did a OD conversion to a 51 F1 and to this day it is a flat head V8 freeway flyer. Tim PS. the OD lockout knob always goes on the right side of the wheel in fords.
pistonbroke is offline   Reply With Quote
Old 01-20-2022, 01:02 AM   #25
Eagle43
I put in an R10. I think it came out of a Mercury car. Do you have a picture of an F1 dash with the OD knob in the factory location? I don't think Canadian F1s came with an OD or a six option. The guy I bought the transmission from had one himself in a 1952 F1 and I just copied his location.
Eagle43 is offline   Reply With Quote
