Old 08-17-2021, 02:20 PM   #1
farmertom
farmertom's Avatar
Default ford holley 94 carb only 1 yr old
i installed a dennis carpenter 94 carb 1 year ago. lately when i drive the '37 which is almost everyday even after being warmed up the idle will creep up. when i come to a turn or a stop[ i need to tap the accelerator pedal to decrease the fast idle. not sure what the cause. linkage seems fine,throttle and choke rods not creeping. any body hjave any problems with new 94s from den carp? thanks tom.
farmertom is offline   Reply With Quote
Old 08-17-2021, 05:03 PM   #2
scicala
scicala's Avatar
Default Re: ford holley 94 carb only 1 yr old
If you're sure the return spring is doing it's job, then chek to make sure the throttle lever on the carb throttle shaft is still peened well, and not sloppy. If sloppy the shaft may not rotate as much as the lever, and cause an inconsistent idle speed. This happened to me one time, and was confusing at first. I peend the lever tighly on the throttle shaft and worked very good after that.
Sal
scicala is offline   Reply With Quote
Old 08-17-2021, 06:52 PM   #3
farmertom
farmertom's Avatar
hey sal,thanks for responding. i'm not quite sure where you mean to peen the lever. would it be possible some time at your conviniance for a picture with a pointer? thanking you,tom.
Old 08-17-2021, 08:10 PM   #4
paul2748
paul2748's Avatar
Check all the linkages for binding. Lubricate any moving parts
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-18-2021, 10:28 AM   #5
Ross F-1
Ross F-1's Avatar
Here is the end of the throttle shaft that is peened at the lever. (arrow)
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-18-2021, 11:40 AM   #6
scicala
scicala's Avatar
Thank you for the picture Ross F-1. I'm not good at posting them on the Ford Barn.
If the fit is sloppy between the lever and brass shaft it can be peened to take out the slop, or the shaft can be drilled and threaded for a short 6-32 screw and washer to hold the lever secure to the shaft.
Not saying this is your problem for sure, but have had it happen to me.
Sal
Old 08-18-2021, 12:15 PM   #7
farmertom
farmertom's Avatar
hey thanks sal and ross f1 for advice and pic.i'll get out and have a look see at the lever and shaft. last summer i replaced probably the at least 2nd carb for this old car with a brand new 94 from dennis carp. kinda nice it seemed to have been set pretty much. i just had to adjust the air/fuel mix screws slightly i suppose cause i put a little 4" hot rod air cleaner vs that big heavy not such good shape oe oil bath. tom.
Old 08-18-2021, 12:28 PM   #8
KiWinUS
KiWinUS's Avatar
Be sure the choke is no creeping on by itself
Old 08-18-2021, 12:53 PM   #9
drolston
drolston's Avatar
Start at the pedal. Be sure the floor mat is not binding the pedal push rod.
