05-12-2018, 08:10 PM | #1 |
Horn Ring
Hello I have a 41 ford trying to get the horn to work.I converted to 12 volts a while back I had no luck with the trumpets so went with a modern horn.I tested the horn and works I have it wired through a horn relay.I am trying to figure out the wire to horn ring how does it break contact.How does the contact plate work.I believe this is a ground wire so this wire is screwed to the horn ring how do I get power
05-12-2018, 08:35 PM | #2 |
Re: Horn Ring
The power is to the relay and from the relay to the horn. The horn wire up the steering column is providing a ground to the relay. When the relay is grounded it is activated and power is supplied to the horns from the relay.
05-12-2018, 08:44 PM | #3 |
Re: Horn Ring
Thank You I need to check my wiring to the relay
05-13-2018, 03:33 AM | #4 |
Re: Horn Ring
Is your horn ring insulator good?
05-13-2018, 08:51 AM | #5 |
Re: Horn Ring
its good
05-13-2018, 03:13 PM | #6 |
Re: Horn Ring
