02-24-2018, 01:55 PM | #1 |
31 S/W 4D TS Rear Window
On a 31 SW TS, are there any window garnishings that go around the rear window?
Is there any items that finish off the rear window as finish the door windows? Thanks, Disregard this post. I found the metal frame that goes around the window. Sorry Last edited by JohnB15632; 02-24-2018 at 03:45 PM. |
02-24-2018, 03:15 PM | #2 |
Re: 31 S/W 4D TS Rear Window
Yes; just one single frame with oval head slotted wood screws. The SW was had with a rear window shade/pull tab. See photo in the judging stds.
02-24-2018, 04:22 PM | #3 |
Other then the frame no other garnish that I know of.
Your rear window looks very familiar, in fact looks just like mine, insulation and all, but with one small differance. Your dome light wiring seems to be routed towards the drivers side, have mine going towards the passender side,
02-25-2018, 12:11 PM | #4 |
What you see in the picture is the ground wire for the dome light. The power wire goes down the passenger side.
Thanks, |
02-25-2018, 12:39 PM | #5 | |
OK, I grounded mine near the light on the body
02-26-2018, 12:52 PM | #6 |
I saw a picture of one once, but I can not find that picture. It was the only I have seen so far with the same garnish that is used on the side windows, that is used on the rear window. Thanks, |
02-27-2018, 08:06 AM | #7 |
This is a pic of mine. I can’t be sure how correct it is as not everything on the car is correct, maybe others can help with that. |
