01-09-2016, 04:41 PM | #1 |
generator assembly question
When assembling the generator, where does the un-insulated field coil wire (the one that connects the two halves of the coil) go in relation to the long clamp bolt; between the bolt and the generator shell, or the other side with the insulator in between? Do you have to form a small "U" loop in the wires to go around the bolt?
01-09-2016, 06:07 PM | #2 |
Re: generator assembly question
