Old 06-24-2015, 11:30 AM   #1
adileo
adileo's Avatar
Default LED tail lights
I know this has many posts, but I have yet to find one that is consistant.
1939 Ford Deluxe
6 v possitive ground
I installed turn sigmals some time ago. I replaced my front parking lights bulbs, with amber bulbs and both front and back lights worked as they should.
I wanted brighter lights in rear - Turn, stop and lights at night.
I bought 6 volt LED and they are much brighter. Please be specific on correct flasher.
Stop lights work
night driving head lights and tail work
Turn signals do not work. I had though that my front parking light had enough of draw to engage flasher......I was wrong.
What do I need to do to get my turn signals working again.
adileo is offline   Reply With Quote
Old 06-24-2015, 11:33 AM   #2
JSeery
JSeery's Avatar
Default Re: LED tail lights
Add resistance to the system OR change the flasher to an electronic unit.
Old 06-24-2015, 11:47 AM   #3
adileo
adileo's Avatar
Jseery thanks - Id prefer flasher change - can I get locally? If yes, What would I ask for at napa?
Old 06-24-2015, 12:18 PM   #4
NealinCA
NealinCA's Avatar
I have a similar issue, but 12V neg ground...and I installed an electronic flasher unit designed for LED lights. It flashes with the key on in the run position, but not with the engine running.
Someone suggested that my old Ford was rejecting the LED's...
Neal
NealinCA is offline   Reply With Quote
Old 06-24-2015, 12:44 PM   #5
CarlG
CarlG's Avatar
Neal
I had that same problem. Went back to the old style flasher and it works just fine. Since then I've made some changes in the wiring schematic that may have solved the problem, but will have to wait a while till I can test it out.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-24-2015, 02:35 PM   #6
JSeery
JSeery's Avatar
Not sure I will have to check. 12v ones you can get anywhere. The LED 6v light suppliers would have them I would think. They should also have the load units. I can check when I get home.
Old 06-24-2015, 04:01 PM   #7
adileo
adileo's Avatar
J thanks I called around no place including where I bought had or knew - best suggestion was add bulbs inline under car to create resistance
Old 06-24-2015, 06:41 PM   #8
cmbrucew
cmbrucew's Avatar
I bought an electronic flasher from Napa years ago to use while towing a trailer.
It could handle one bulb or six, made no difference. Worked, but very loud.
I kept it in the boat to use for towing only.
Works good
Lasts long time
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 06-24-2015, 06:52 PM   #9
adileo
adileo's Avatar
I bet it was 12 volt
Old 06-24-2015, 07:20 PM   #10
cmbrucew
cmbrucew's Avatar
Sorry, you are right. Senior moment.
Bruce
Works good
Lasts long time
Old 06-24-2015, 07:32 PM   #11
JSeery
JSeery's Avatar
Couple of maybes.
http://www.6vrelay.com/
http://www.banggood.com/6V-12V-2-Pin...-p-967336.html
http://www.wrenchmonkees.com/mini-fl...ay-6v-12v.html
http://www.ctaservice.se/delar/LEDblink/LEDblink.htm
Old 06-24-2015, 07:51 PM   #12
adileo
adileo's Avatar
J - thank very much for your time and your help. I guess a relay is really only option to get the turn signals working.
I'm probably going to go with: https://www.ronfrancis.com/prodinfo.asp?number=LR%2D26
I'll put one on each stop light line and mount to frame near each light.
I am amazed at the difference in brightness with these new volt 6 LEDs.
Old 06-24-2015, 08:00 PM   #13
JSeery
JSeery's Avatar
That should work.
Old 06-25-2015, 04:23 PM   #14
Boss1940
Go with the Ron Francis components , it will work
Boss1940 is offline   Reply With Quote
Old 06-25-2015, 04:25 PM   #15
adileo
adileo's Avatar
Thanks Boss hope all is well - Francis order is in.
Old 06-26-2015, 08:29 PM   #16
adileo
adileo's Avatar
Grrr - I installed the resistors (2 for $40) made little difference - anyone know of a no load pos ground 6 volt flasher?
I even tried doubling up the resistors to one turn signal.
Old 06-26-2015, 09:11 PM   #17
Jack E/NJ
Jack E/NJ's Avatar
What is the bulb wattage? How many ohms per resistor? And did you install the resistors in series or parallel with the bulb?
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 06-26-2015, 09:45 PM   #18
adileo
adileo's Avatar
The front 6 volt bulbs say 55 & 11a not sure what that means but they are the parking lights for 39 Deluxe.
All I did was pulled the bullet connector apart to led tail lights under car and spliced in the resistor - pic and details for resistor above purchased from Francis wiring and they are made for 6 volt led
Thanks in advance for any help
Old 06-27-2015, 03:16 AM   #19
TomT/Williamsburg
TomT/Williamsburg's Avatar
Call rodworz - 1-877-763-9679 - they will have the answers ... just got a nice demo/explanation at their booth at the Ricky Mountain NSRA Nats here in Pueblo, CO. They have the correct flasher to correct your problem.
TomT/Williamsburg is offline   Reply With Quote
Old 06-27-2015, 06:08 AM   #20
adileo
adileo's Avatar
Thx Tom I'll give them a call.
These leds tail lights are super bright and much safer than stock.
