03-09-2015, 08:40 PM | #1 |
Bent starter armature shaft
What happens when you have a starter armature shaft that is not true? Can you straighten it or do you scrap it? When you look in Bert's Catalog they say that if you want a rebuilt one the core you send should not be bent.Any comments?
Thanks, Marc |
03-09-2015, 08:49 PM | #2 |
Re: Bent starter armature shaft
I put mine in a lathe and straighten it. Usually what bends one is someone tried to start the car with the spark advanced and it kicked back and bent the armature.
03-09-2015, 09:12 PM | #3 |
Straighten it ---I have done many, at first with a wood mallet, now I have a press ---I have also used a large vice and a pipe
03-09-2015, 09:22 PM | #4 | |
Joe K
Shudda kept the horse. |
03-09-2015, 09:54 PM | #5 |
I have straightened mine. I made a jig to do it. It was easy and the jig I made worked real good. When I pretty it up a bit I will post a couple pictures. I threw the question out to see the opinions of others on the subject....thank you
03-09-2015, 09:54 PM | #6 |
03-09-2015, 09:59 PM | #7 |
Gees Tom, that is very similar in design and theory to what I came up with.
03-10-2015, 01:37 AM | #8 |
used a cheater pipe extension, then checked for deflection by rolling the armature on a flat surface.
I like tom's machine better. Bob |
03-10-2015, 01:44 AM | #9 |
Tom sure surpassed Thomas Edison in the invention department a long time ago!!!!!
'31 180A |
