09-24-2021, 01:13 PM | #1 |
Whoops
Working on a rear brake assembly things were going to smooth . I put the E-brake return spring on the wrong lever I had 4 springs two silver and two black .
Dennis in Kelsey ca |
09-24-2021, 01:32 PM | #2 |
Re: Whoops
Dennis, did you use the notched 2 screwdrivers to install the spring - see picture attached. They make the job much easier.
Rusty Nelson |
09-24-2021, 02:00 PM | #3 |
Re: Whoops
Thanks Rusty maybe I'll make a couple to get it off .
09-24-2021, 04:48 PM | #4 |
Re: Whoops
Dennis Pereira working on a rear brake assembly |
09-24-2021, 04:50 PM | #5 |
Re: Whoops
Notched Screw Driver - wrndln |
09-25-2021, 07:19 AM | #6 |
Re: Whoops
09-25-2021, 01:26 PM | #7 |
Re: Whoops
I agree that's the way I'm doing it also but my body is off the frame .
