Old 09-21-2021, 11:50 AM   #1
Dennis Pereira
Dennis Pereira's Avatar
Default Rear Drum Seal
What tool is used to remove seal ? I don't want to damage the bearing none of the pullers I have will fit . 28 - 29
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
Old 09-21-2021, 01:15 PM   #2
Dennis Pereira
Default Re: Rear Drum Seal
Thanks anyway I found my angled pry bar and slid it into the axle hole and under the edge of the seal drove it down on the anvil .
Dennis in Kelsey ca
Old 09-21-2021, 08:31 PM   #3
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I'm glad that you were able to remove your seal. I have a seal removing tool but I prefer the drum dropped on a piece of cardboard or carpet over concrete repeatedly until the bearing pushes the seal out.
Ivan in southeast va. is offline   Reply With Quote
Old 09-21-2021, 09:13 PM   #4
flybob08
I definitely like the simplicity of that method
flybob08 is offline   Reply With Quote
Old 09-21-2021, 10:01 PM   #5
ursus
Ivan has it! Always worked for me.
Old 09-21-2021, 10:49 PM   #6
Dennis Pereira
That would have never worked the seals had been staked .
Dennis in Kelsey ca
Old 09-22-2021, 05:25 AM   #7
Patrick L.
Patrick L.'s Avatar
Doesn't sound like we're referring to a Model A.
Old 09-22-2021, 10:35 AM   #8
katy
katy's Avatar
A picture would definitely help.
Old 09-22-2021, 02:26 PM   #9
Dennis Pereira
I used the search option before I started the rear drum seal removal . there's a lot of different methods to remove the damaged seal . And if you are trying to save the seal slamming it on the concrete might work for you . It was one of the methods used to remove bearing and seal .
Dennis in Kelsey ca
