Old 11-29-2020, 09:44 AM   #1
flat 39
flat 39's Avatar
Default Cam Gear Noise
I have finally determined that the noise i have been hearing is cam gear noise. it happens at about 2000 RPM under light load. I'm using the aluminum gear. Ford used a fiber gear to eliminate the noise. my questions are:
1) is this common?
2) is this something i should be concerned about or just let it annoy me.
flat 39 is offline   Reply With Quote
Old 11-29-2020, 09:50 AM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: Cam Gear Noise
Never heard cam gear noise, not sure what can cause it. But, someone here will know.
Gramps
Old 11-29-2020, 12:40 PM   #3
cadillac512
cadillac512's Avatar
I'm trying to figure why light load would change the noise if it's cam/crank gear related. There is so little difference in loading on the cam and gears whether or not the engine is loaded,accelerating or decelerating. I guess a backlash check and gear inspection might tell something, but cross your fingers...
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-29-2020, 04:20 PM   #4
deuce5wndw
deuce5wndw's Avatar
If there is no fillings in your oil at change then your exhaust is too quite!
deuce5wndw is offline   Reply With Quote
Old 11-29-2020, 04:33 PM   #5
Mac VP
Mac VP's Avatar
Also you may have to check the length of the four bolts that secure the gear to the camshaft, making sure one or all four don’t stick out the back side too much. The front block plug is also in this area.....make sure it’s flush with the block.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 11-29-2020, 06:51 PM   #6
Talkwrench
Talkwrench's Avatar
Mine makes a "whirring" noise under light load - idle, Ive put it down to the Ali gear [press on]
