06-04-2017, 09:25 AM | #1 |
Removing ridge from cylinders
It appears that I must have steel sleeves in my 1937 flathead. My ridge reamer will not cut the ridge. Any suggestions on how to remove the ridge to get the pistons out? thanks
06-04-2017, 10:41 AM | #2 |
Re: Removing ridge from cylinders
Just wondering why your ridge reamer won't do the job?
Can you post a photo of your reamer and ridge set up? |
06-04-2017, 12:01 PM | #3 |
I have ordered a new carbide cutter for the reamer but haven't received it. Thanks
06-04-2017, 12:12 PM | #4 |
The sleeves are too hard for a ridge reamer.
I have to ask: If you have ridges, why are you worried about removing them? It's obvious the bores are worn too far to simply replace rings and machine work is necessary. If you are attempting to salvage the pistons from an otherwise poor block, use a small die grinder to cut away the ridges.
06-04-2017, 12:59 PM | #5 |
What you have in your hand is a HONE,,,what ever the package says.
06-04-2017, 02:47 PM | #6 |
06-04-2017, 02:55 PM | #7 |
Me to. Not a hone.
06-04-2017, 03:28 PM | #8 |
OK,,,,,,,,,,never seen one like that,,,
06-04-2017, 03:52 PM | #9 |
I haven't used one in years . . . and don't see much of a purpose as when the cylinder is that worn, I'll rebore it to a larger size . . . or put new sleeves in it. Have you measured the bores to figure out how worn they are?
06-04-2017, 04:47 PM | #10 |
Just a guess , he wants to resleeve and reuse Pistons . No sense in busting up some Pistons that may have a new home .
06-04-2017, 05:39 PM | #11 |
If sleeves are that worn it is hard to believe the pistons are usable.
06-04-2017, 08:48 PM | #12 |
At the very least, the ring lands will be worn.
06-04-2017, 09:02 PM | #13 |
Steel sleeves and aluminum pistons. Which is going to wear the most?
06-04-2017, 09:28 PM | #14 |
V12Bill>>>Steel sleeves and aluminum pistons. Which is going to wear the most>>>
Hmmm? Sounds like a trick question. I'll guess the sleeves the most. The pistons least. And the rings in between. Did I guess right? 8^) Jack E/NJ |
06-05-2017, 07:50 AM | #15 | |
Of course, from what I read on the Barn and other forums, most guys don't really "rebuild", at least not correctly.
06-05-2017, 08:02 AM | #16 |
I believe the pistons used with the steel liners were also steel.
06-05-2017, 08:07 AM | #17 |
I looked at the pictures that were posted earlier - pretty heavy ridge is visible. The sleeves look like the ole' "tin can sleeves" that Ford would put in many of their early 24 stud - 221 cubic inch Ford engines (though I didn't know they did it back in 37 - maybe a later 'rebuild'???).
Me, I would look for a new set of sleeves and associated pistons/rings . . . and rebuild it to tip-top shape. With that said, I'm not trying to spend your money - just talking about the best way to do the job. Best of luck, B&S |
06-05-2017, 09:09 AM | #18 |
Go borrow one from Autozone and see it will do the job.
06-05-2017, 09:35 AM | #19 |
Remove sleeves and bore to 239 CID
06-05-2017, 10:03 AM | #20 |
I've done that and wow, well worth it. And, from my experience I got a stronger engine with less of an investment than R&R sleeves.
