11-28-2020, 03:24 PM | #1 |
Original Champion Flathead Spark Plug Question
Hey guys... So I have an original set of Champion 48-12405-A2, 6 COM Flathead spark plugs. From the little bit of info I can find on them looks like they are for earlier flatheads. Will these plugs work fine on a ‘45 59AB? See attached photos. Thanks so much for the info!
11-28-2020, 03:59 PM | #2 |
Re: Original Champion Flathead Spark Plug Question
'45 used 14mm plugs, are they 14mm? or 18mm which is '37 and older
11-28-2020, 04:05 PM | #3 | |
11-28-2020, 06:04 PM | #4 | |
11-28-2020, 06:04 PM | #5 |
Just run NGK B6L plugs
11-29-2020, 05:54 PM | #6 |
11-29-2020, 06:10 PM | #7 |
You would probably be quite surprised at what that NOS set would be worth to a true restorer. Don't just use them in something 'cuz they fit! DD
11-29-2020, 11:06 PM | #8 |
That is the correct plug for a 1960 John Deere 630 .
11-29-2020, 11:35 PM | #9 |
And it only requires two!
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
11-29-2020, 11:37 PM | #10 |
You sure, David? That looks like a '35 Ford part number. DD
11-30-2020, 11:09 AM | #11 |
They look a little short and fat compared to the J 10 or H 10 Champions we always used in the flatheads from 39 up. Still running some ancient Champions like that in the 52 Merc. and they work fine.
https://www.youtube.com/user/roosty6/videos |
11-30-2020, 11:49 AM | #12 |
The parts book shows Spark plug-heavy duty service cars (No. 6 Com'l) 1935-36
