04-13-2019, 02:33 PM | #1 |
What about New Starter Bendix?
I searched and googled, just found for sale adds and Ford Tractor posts. I haven't yet held one of the newer type Bendix in my hand. Got 4 or 5 of the old ones here now, tried 3 and they work fine. I'm wondering what's different with them and why? Just like to know, you know. Thanks!
04-13-2019, 04:00 PM | #2 |
Re: What about New Starter Bendix?
Many modern repros are made offshore to metric dimensional specs, while disregarding metallurgical and performance specs. Is there something else you need to know about any modern repro?
Alan |
04-13-2019, 05:00 PM | #3 |
Because I had had the starter hang up a few times, I replaced the starter Bendix on my 59A/B with a reproduction stock type unit when I converted the starter to 12 volts. Cheap import crap did not last 20 starts before it sheared. I replaced it with the modern mushroom looking replacement type (also of unknown manufacture origin) and that unit has performed reliably for three years, - maybe 100 starts}.
Good luck! |
04-13-2019, 06:04 PM | #4 |
After switching to 12 volts I had a lot of trouble breaking Bendix springs. Switched to the new style four years ago and haven't had any problems. If you stay with 6 volts the old style should work fine.
04-13-2019, 06:43 PM | #5 | |
What are differences with new type any why is what I'm wondering. Thanks, guys! |
04-13-2019, 07:37 PM | #6 |
04-13-2019, 08:13 PM | #7 |
I believe Mac Van Pelt has original quality Bendix's
Making the simple complicated for over 30 years. |
04-13-2019, 09:43 PM | #8 |
none of it is a ford part, starter included. stromberg built carburetors, autolite built starters, bendix built the starter drives, etc. thats how all the makers do it for many small parts. the "new style", is just that, its a newer design from bendix that was used on the later fords, and ive had them on army jeeps, and i'm sure many other applications too. there can be a variety of gear tooth count, and rotation, for different apps. i've never had one apart, but i believe there are small clutch paks in there instead of using the spring to absorb the shock. better? well the engineers want us to believe newer is always better, but, that theory doesnt always work. then theres the really new, as in offshore cheaper made junk. ask mac vp, he would have an answer i'm sure
04-13-2019, 10:31 PM | #9 |
correct I got one from Mac VP.... made in USA.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
04-14-2019, 05:53 AM | #10 |
Of the original Bendix design (the type with the exposed spring and gear) there are cheap imported units on the market.....I have no idea about their quality or operational longevity. And there is the one made in the USA by an old starter drive manufacturer. This is the one we’ve always supplied and trusted. We buy our starters without the modern barrel drive (which incidentally is too big in diameter to fit into the 49-53 V8’s without grinding something to make it fit) and we install the USA Bendix drive ourselves.
04-14-2019, 06:46 AM | #11 |
Three (3) years ago I bought ($200) one of the new starters with new Bendix. They don't tell you that you have to grind away part of the bell housing for it to fit until you get the part in the mail. There is a small sketch in the box that my 5 year old Grandaughter could draw better than what you have to look at ! It's really STUPID !!
After hours of grinding away.....I finally got the new one to fit and bolted it up with the help of a buddy from garage up the road. Everything secure....we started it up....it would barely turn over and then Solenoid started to smoke and burn up. Replaced the Solenoid and it happened again ! Bought another new solenoid.....took out the new starter....replaced it with a Bendix that a friend had with my Old Starter and installed. Started right up and not one problem since. That was 3 years ago and as of this writing no probs !! Took the new starter and Bendix threw in the trash along with 2 solenoids !!! End of that story ! If you would have seen the sketch that was in the box of what you had to do to install....you'd laugh like hell ! I cannot believe they would even use it. I cannot be the only one that called to complain ! Thx....Mike |
04-14-2019, 07:59 AM | #12 |
I have had good luck with the USA barrel bendix in Model As.
I put one in my newly rebuilt 59a. After some miles the engine developed a ticking sound that would come and go. I finally thought it could be the Bendix hitting the ring gear and going back k and forth. I put in new USA original style Bendix and the noise went away. One of the many mysteries of Flatheads. John
Welcome each day |
