11-20-2014, 06:58 PM | #1 |
Mitchell in a 39 Ford
Anyone installed a Mitchell in a 39 Std. Coupe. I was wondering if the floor pan has to be modified. Sue Mitchell says it is 17 inches from the banjo flange to the back of the gearbox which makes it very close to the floor pan step down.
Thanks John |
11-20-2014, 08:47 PM | #2 |
Re: Mitchell in a 39 Ford
Mitchell?
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
11-20-2014, 08:56 PM | #3 |
Mitchell manufactures an overdrive unit that is mounted in the drive tube.I have one in a model A that works fantastic.I inquire to Mitchell about installing on in my 36,the floor needed modification so I didn't follow thru on the installation.I also am curious about installing in a 39.Phil
11-20-2014, 09:42 PM | #4 |
11-21-2014, 06:45 AM | #5 |
Mac's catalog,states 35&36 Tudors & fordors need floor modifications.To their knowledge,all other models don't! I'd like to have one...but there pricey.
11-21-2014, 07:55 AM | #6 |
11-21-2014, 08:37 AM | #7 |
I have a Mitchell in our 37 sdn and it fit without any floor mods. I believe the 37 thru 40 are the same. It dosen't have much clerance but with 2 big guys in the back seat all is well. The part that is close to the drop down in the pan is the shifter lever that slides the gear box in and out of od. You should be fine, however if you have replaced the floor pan you may need to put a small dent in the pan or grind a small radius on the shift fulcrum.
Regards, Don |
11-21-2014, 08:47 AM | #8 |
Thanks for the information Don
11-21-2014, 08:58 AM | #9 |
I have a Mitchell installed in a 33 3-w . It is very close to the floor. I made my Mitchell shift gears with electric door solenoids. It took a little bit of experimentation. I think if I did it again. I would use of electric motor pulls . They would pull with a little more strength and would be positive. Sometimes the door pulls don't get it all away into gear. I also made a switch that looks like a Columbia overdrive switch but in fact is just an electric switch that makes the Mitchell shift gears.
11-21-2014, 09:13 AM | #10 |
I have a Columbia for our '39 LZ. But I'd like to install a Mitchell in our '39 Ford CS. I've also heard that you have to modify the floor pan to install a Mitchell in a '39. Has anyone done the installation in a '39 (of any body style)? And, if so, did you have to do anything to the floor pan?
11-21-2014, 11:18 AM | #11 |
I just ordered one for my 39 std coupe so we will find out. I will report the results.
11-21-2014, 12:56 PM | #12 |
Excellent, hope its an easy install. Looking forward to hearing about your installation.
11-21-2014, 02:27 PM | #13 | |
Lever pull is just to the right of my tach. John |
11-21-2014, 03:59 PM | #14 |
11-21-2014, 04:03 PM | #15 |
John,About how long did it take install the Mitchell?Is your engine stock?My Merc.with the Columbia is almost 300 ci. Hill climbing in high,high is not a problem,I really do not down shift much.I am wondering about a stock engine with a Mitchell.Phil
11-21-2014, 04:33 PM | #16 |
I personally prefer the F150 4-Speed OD tranny. Gives you synchro in all gears and 4th gear is OD. You shift into OD just like any other gear. www.modelaonly.net
11-21-2014, 07:17 PM | #17 |
Hi planojc, you will love the Mitchell. I have 30,000 mi on mine and it is flawless so far. I have the same setup that oldford2 has, the cable works very well and is inconspicuous. What ratio did you end up with?
I have the 28% and with my 276 I seldom shift out of od. regards, Don |
11-21-2014, 07:34 PM | #18 |
dont want to ruffle any feathers but a properly built columbia is reliable and cool as heck. no disrespect to mitchel there fine units.
11-22-2014, 10:32 AM | #19 |
get a columbia rear they work best. G.m.
www.fordcollector.com |
11-22-2014, 10:45 AM | #20 |
Jake, You got it. I have 8 old Fords with Columbia's some for over 30 years with NO problems. I have the original controls but built my own. I use a duel fuel tank switching valve made for fuel injected engines. It has 6 ports which I run the vacuum through. I put a momentary push button switch on the underside edge of the dash, and a switch on the clutch arm. The operation is hold the dash switch and push and hold the clutch. Release the clutch then the dash switch and your in Columbia. To get out of Columbia just push the clutch and it's out. One has been working over 30 years and 130,000 miles. G.M.
11-22-2014, 05:51 PM | #21 |
Here we go again.
11-24-2014, 08:56 PM | #22 |
Planojc please post pictures of your Mitchell install if you can. My dad has a 37 and I have a 38. We both are interested in the Mitchell unit but don't want to modify our floors.
11-24-2014, 11:22 PM | #23 |
Will do. They told me it would ship around the end of Jan. FYI the clearance needed is 17 inches from the banjo flange to the front of the OD gearbox. On my 39 coupe the floor pan step down is about 17.5, so it should clear without any mod.
01-29-2015, 10:01 PM | #24 |
Planojc, did you get your Mitchell?
01-30-2015, 09:29 AM | #25 |
Called Sue and it should be shipped in a week. Their lead time on shipping is approx. 10-12 wks I will update after the install.
01-30-2015, 12:17 PM | #26 |
Exception
03-07-2015, 10:28 AM | #27 |
Planojc, do your Mitchell come in yet? Really curious about clearances under your car.
03-07-2015, 05:38 PM | #28 |
i wired a switch in so if u want,the columbia wont disengage every time u push the clutch in.on my 46 coupe.i have a complete one all ready to go in my 39 coupe.just havent had time.od is great! dont matter what it is.so much more fun to drive.
03-07-2015, 05:49 PM | #29 |
Starting a C out in high range is hard on the innards. I did it for a while years ago before I saw what can happen. I was lucky and never did any damage. The C was designed for torque tube fords and in no way depends on 6 bolts to handle the torque and push pull associated with the 32-48 drive train.
