11-04-2013, 07:59 PM | #1 |
Generator woes
I have a "rebuilt" generator that doesnt charge. I've had it off and it will motor, slowly, in the correct direction. In fact, it will motor ( because the belt is too loose) after the engine is shut off. I thought that maybe the cutout was sticking, but after the battery is disconnected it quits (of course). After reconnecting it again, it doesnt motor, until after the engine is ran again, then its the same scenario.
While the engine is running, the stud at the front of the cutout, where the generator output is supposed to be, will measure about 9 volts, but the other side of the cutout, where the battery is connected, wont measure anything. However the ammeter will show about a 10 amp charge rate, even though it doesnt seem to be charging the battery. With the engine off, there is no continuity from the output stud to the battery connection on the cutout, which to me means its not sticking. There is continuity from the output stud to the two mounting screws on either side. I dont see how this can be correct, but I'm not sure. Any help will be appreciated! |
11-04-2013, 08:46 PM | #2 |
Re: Generator woes
Run the engine at fast idle, then use a jumper wire between both sides of the cutout. Does the ammeter now show a charge?After this check remove the jumper and stop the engine and read the voltage at the generator stud and ground. What is it?
Sure seems like a bad repro cutout. |
11-05-2013, 07:06 AM | #3 | |
Re: Generator woes
So with that, I guess the cutout is sticking after all ? I'm open to suggestions about a replacement ( diode?) and a source for a quality one. I grew up in the era where if you needed a good electrical part you went to NAPA and asked for Echlin, but I havent checked to see if they make Model A parts...and I'm pretty sure even if they do they dont have enough demand to stock them locally. Thanks for your help Tom. |
11-05-2013, 07:24 AM | #4 |
Re: Generator woes
Bert's has restored original cutouts or you could use a diode cutout.
A&L makes quality diode cutouts and they and some of the parts houses sell them. I always use a restored original cutout and never have had a problem. BTW, it seems your generator is adjusted for too much output. I wouldn't set it for more than about 2 or 3 amps, unless you do a lot of short drives, then maybe 5 amps. |
11-05-2013, 07:37 AM | #5 | |
Re: Generator woes
Thread Tools | |
Display Modes | |
