Old 12-19-2016, 05:55 PM   #1
sphanna
sphanna's Avatar
Default Where to get a Bill Stipe distributor cam
I would like to know where or how to purchase a Bill Stipe dist. cam for my Fordor.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 12-19-2016, 05:59 PM   #2
CarlG
CarlG's Avatar
Default Re: Where to get a Bill Stipe distributor cam
To Order From Specialty Motor Cams and
Stipe Machine Call: 920-467-2895
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-19-2016, 06:11 PM   #3
sphanna
sphanna's Avatar
Tried that but got the fax machine. I'll try again. Thank you for confirming the number.
Old 12-19-2016, 06:49 PM   #4
CarlG
CarlG's Avatar
I just took that number off their web site.
I know that when I bought mine, I just ordered from them direct, but that's been several years ago.
Alaskan A's
Old 12-19-2016, 07:20 PM   #5
700rpm
700rpm's Avatar
Send them a fax.
Ray Horton, Portland, OR
Old 12-19-2016, 07:28 PM   #6
updraught
updraught's Avatar
The one on the Brattons web site says:
"New aircraft strength 1144 steel, with a Rockwell hardness of 23, and precision ground to within .0005 to meet Fords original specifications; polished for smooth surface. the best on the market. This is the Model 'B' cam. The 'B' cam creates twice as hot a spark as the 'A' cam, resulting in longer spark plug life."
What's the difference?
updraught is offline   Reply With Quote
Old 12-19-2016, 09:44 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
The dwell time on the B cam is about 10 degrees more than the stock A cam, and this allows the coil to build a stronger magnetic field at higher speeds. Stronger magnetic field means a hotter spark. I can't believe it would be twice as hot a spark, unless that was at the extreme top RPM range, which most of us never approach.
Old 12-20-2016, 12:15 AM   #8
Mike V. Florida
Mike V. Florida's Avatar
There might not be any. Call them and ask where they get them from.
Old 12-20-2016, 09:14 AM   #9
sphanna
sphanna's Avatar
I'll call Bratton's. Maybe it is a Stipe's cam. Thanks
Old 12-20-2016, 09:31 AM   #10
Tom Wesenberg
Even if it isn't, I've checked the cams I bought from Bratton's and found them to be very accurate.
Old 12-20-2016, 09:48 AM   #11
Mitch//pa
I use the Brattons cams. Exc quality
Old 12-20-2016, 06:55 PM   #12
JohnLaVoy
JohnLaVoy's Avatar
Specialty Motor Cams (920) 467-2895 They are USA made more dwell than most of the cams to give a better performance. About $12.50 each and have them in stock.
JohnLaVoy is offline   Reply With Quote
Old 12-20-2016, 07:11 PM   #13
AL in NY
AL in NY's Avatar
John, I believe that's the fax number.
sphanna: try this number for Bill Stipe 920-467-9700
AL in NY
AL in NY is offline   Reply With Quote
Old 12-20-2016, 10:05 PM   #14
sphanna
sphanna's Avatar
Thanks Guys Appreciate the help and info
Old 02-16-2020, 05:49 PM   #15
RB_Nielsen
RB_Nielsen's Avatar
FYI - ordered (using website ph#) and just received qty=2 Stipe dist cam (@$14.95)
RB_Nielsen is offline   Reply With Quote
Old 02-16-2020, 06:40 PM   #16
rotorwrench
rotorwrench's Avatar
4-cylinder engines never had a problem with dwell time. It's the V8 that had problems requiring two sets of breakers to increase dwell time. I would doubt if the high tension build would be much higher in voltage with a different breaker cam. If it is, the amount would likely be negligible. An oscilloscope would confirm ya or nay in any case. Coils gain saturation very rapidly and the engine only fires two plugs per crank revolution on a 4-banger. The model A engine is not a real high rpm engine in stock form.
