01-31-2018, 02:00 PM | #1 |
21 inch rim repair
I was trying to salvage a straight 21" wheel with pin holes in the inner rim, but kept blowing holes through it, even with my welder turned way down. I can JB weld it after my powder coat guy is done, but media blasting will likely deposit a lot of material inside that rim. How do you guys fix pin holes and thin metal on these wheels? 21's are not as plentiful as they once were, and I would like to save the ones I find with this issue.
01-31-2018, 02:09 PM | #2 |
Re: 21 inch rim repair
That's a good question and a tricky safety issue, considering thin metal on a wheel rim.
01-31-2018, 02:38 PM | #3 |
A person that is experienced at gas welding probably wouldn't have that much of a problem . Gas welding seems to almost be a lost art .
01-31-2018, 02:39 PM | #4 | |
if its that thin a low power welder is blowing thru the whole wheel is compromised. Id hate to have you fold a rim going around a corner or something. Rims are still out there - just have to travel farther.
01-31-2018, 03:05 PM | #5 |
I've had good luck Tig welding them
01-31-2018, 05:04 PM | #6 |
01-31-2018, 05:55 PM | #7 |
Take out a LOAN & buy NEW wheels!
Bill Safe
01-31-2018, 08:52 PM | #8 |
A loan indeed. I'm too cheap for that. Regarding safety, I think the wheel in question was in one position for a very long time, as the two or three pin holes are concentrated in a four inch span. The metal around the holes is good and thick, but it takes a lot of weld filling to reach the good "meat'. All total, I don't think a pencil would fit in the holes that opened up.
01-31-2018, 09:16 PM | #9 |
I agree with Bill, Buy another rim, I repaired a similar rim and it spit in half while on a tour. Luckily we were going slow and didn't get hurt or have any car damaged. I still have it and should post a picture so know body else makes the same mistake.
01-31-2018, 09:20 PM | #10 |
I intended it to be used as only a spare but ended up on the car. I hit a pot hole and that was the end of it. I was very lucky.
02-01-2018, 11:02 AM | #11 |
just sold 4 roadworthy 21's at Turlock, $70.
______________ Nothing Short of Right is Right |
02-01-2018, 11:23 AM | #12 | |
If you need MONEY, call my Dog @ 1-800-DOG-HELP Bill Nuts
02-01-2018, 04:28 PM | #13 |
I would not use those wheels,if you had those dipped you would wind up with swiss cheese!
02-01-2018, 10:30 PM | #14 |
It would be REALLY good if Coker were to make a wheel with a 4 inch rim.
These could be sold with the radials to suit. A guy making rims here went out of business several years ago. To get 4 inch rims from the UK ... bought in pounds, with shipping and mounting on a wheel center is too expensive. |
02-02-2018, 10:39 AM | #15 |
Try backing it up w/a big piece of copper, or maybe brass.
02-02-2018, 08:18 PM | #16 |
In past years, to get the loose rust out of the beads on 21" wheels, I drilled 4 1/4" holes on the inside of the bead at a equal distance; I then inserted a small cable and attached the end to a drill so I could knock any rust loose. I then worked all the loose rust out. I did not fill the 4 holes as they would not be seen when the tires were mounted; then had the wheels powder coated. Never had a problem with the wheels.
Ron |
02-03-2018, 01:25 AM | #17 | |
02-04-2018, 01:26 AM | #18 |
How can water get to holes on the inside of the bead when the Tire seals to the inside of the bead ?
Ron |
