Old 01-15-2021, 08:24 PM   #1
dlfrisch
dlfrisch's Avatar
Default Grease Fittings
I poked a needle into my stock Ford grease fittings ( to make sure they weren’t plugged), but when greasing, I don’t know if grease is entering, it just squirts out around the fitting.
I would like to change the stock grease fittings and install Zerk type. How do you remove the factory fittings an install the new Zerk type ? It seems as though they are just pressed in. Can anyone help?
Dave
dlfrisch is offline   Reply With Quote
Old 01-15-2021, 09:38 PM   #2
shew01
shew01's Avatar
Default Re: Grease Fittings
You can bump the unthreaded fittings out with a hammer and small chisel or screwdriver. The vendors sell replacement fitting sets like this.
https://www.brattons.com/28-29-origi...tting-set.html
However, it can be hard to drive the friction fit fittings back into the suspension. The threaded fittings work fine.
shew01 is online now   Reply With Quote
Old 01-15-2021, 11:25 PM   #3
CarlG
CarlG's Avatar
Getting the old ones out is pretty much like pulling teeth. Grab them with a pair of vice grips and rock them back & forth while pulling.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-16-2021, 07:07 AM   #4
shew01
shew01's Avatar
That’s a good analogy.
Old 01-16-2021, 09:27 AM   #5
Gene F
Gene F's Avatar
It could be that the sleve / bushing in there is rotated around blocking the passage. I think I have one that is doing that. Sometimes I can get grease into it, sometimes not.
