Old 05-20-2020, 08:24 PM   #1
Bursonaw
Bursonaw's Avatar
Default Convertable top iron rivets
I am replacing the worn rivets on my roadster’s convertable top irons. I’ve been told that someone makes special bolts that look like a rivet when put together. Does anyone know where I can purchase these rivet/bolts?
Tony
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 05-21-2020, 08:26 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Convertable top iron rivets
Will these rivet bolts work?
https://www.google.com/search?q=rive...5R_OBvBLu7AgM:
Old 05-21-2020, 10:19 AM   #3
Karl Wescott
Karl Wescott's Avatar
What year roadster? 1932 is very different than 1933-36. Are you restoring where head profile is important or a street rod where appearance but not necessarily authenticity is important?
There are no commercially available "rivet bolts" of the size needed for top irons that I know of, there are a couple of options for true rivets.
Karl Wescott is offline   Reply With Quote
Old 05-21-2020, 07:47 PM   #4
Bursonaw
Bursonaw's Avatar
The top irons are on a 1936 Roadster. I found these at McMaster-Carr, they are not exact but look like they might work.
Old 05-21-2020, 10:27 PM   #5
jimvette59
jimvette59's Avatar
What size do you need ?
jimvette59 is offline   Reply With Quote
Old 05-21-2020, 11:36 PM   #6
Bursonaw
Bursonaw's Avatar
1/4” diameter 5/8” shank. I ordered what I think will work from McMaster Carr. Hopefully they will work.
