08-10-2018, 08:22 PM | #1 |
8BA Distributor Vacumn line
Doe's anyone know were I can purchase an 8ba distributor vacumn line ? Mine wont tighten down at the distributor. the fitting tightens but the line pulls out of the fitting. Stock 8BA . Thanks ray
08-10-2018, 08:56 PM | #2 |
Re: 8BA Distributor Vacumn line
When you put the fitting on the tube, does the tube extend beyond the end of the fitting? If it does not then the fitting will not pinch the tube when it is tightened.
08-11-2018, 03:33 AM | #3 |
51 Merc-ct, it does but won't tighten. I think its the wrong fitting, as it is different than the one that goes to the Carb. Does anyone sell the fittings?
08-11-2018, 05:01 AM | #4 |
Weatherhad 6100x3 i think...should be available at NAPA or online
08-11-2018, 05:11 AM | #5 |
It should look like the top pic.
I have in the past fixed one by using a brake line fitting plus a ferrule as in lower pic.
08-11-2018, 08:33 AM | #6 |
08-11-2018, 09:21 AM | #7 |
How do threads on fitting look? Make sure you are not cross threading the fitting. These require a bit of finesse to get them started correctly as the line wants to pull them sideways.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
08-11-2018, 12:38 PM | #8 |
I had the same problem. I started the fitting but just before I started to feel resistance I pushed the line in as far as I could and then tightened. Works fine.
08-11-2018, 03:25 PM | #9 |
Hi to all , thanks for all the info. I was able to get the weatherhead fitting at Napa. It is tight once again. Ray
