03-03-2015, 04:29 AM | #1 |
1937 Ford 1/2 ton door latches question
I was wondering if anyone has purchased the aftermarket door latches available from various venders. How is the fit? also working functions. 37 Ford 1/2 ton Panel. Thanks Ray
03-03-2015, 02:48 PM | #2 |
Re: 1937 Ford 1/2 ton door latches question
Just to clarify, there are only two possibilities for aftermarket latches.
The first is the NORS service replacement made by (i believe) by Swis. This is the same latch as OEM to Ford, less the inside handle mount and link. The current repro latch is by Drake. Regardless of who you get it from it will be Drake's. I have not gotten any reports on these... good or bad. |
03-03-2015, 06:13 PM | #3 |
Thanks Karl
03-03-2015, 08:01 PM | #4 | |
03-03-2015, 08:26 PM | #5 |
I need to learn to read a little better. I saw 32 not 37. Carl is right and I can't read. Deleted my post so as not to confuse the point. Sorry.
03-04-2015, 08:01 AM | #6 |
I'm happy with them. |
