Old 07-04-2013, 06:36 PM   #1
Ray Balukas
Ray Balukas's Avatar
Default Model 94 Carb issue
The accelerator pump linkage is popping out of the throttle linkage. it has been in the center hole. What holds the linkage to the throttle linkage? I had the Carb rebuilt a year ago , it has no miles on it. I have only started it in the Barn. Thanks Ray
Ray Balukas is offline   Reply With Quote
Old 07-04-2013, 07:18 PM   #2
Charlie ny
Default Re: Model 94 Carb issue
Ray,
The small link that connects the arm to the actuating rod has a groove in it.
That groove snaps into a spring loaded ball at the end of the actuating rod. After a
zillion strokes and existing in a dirty environment that spring loaded ball gets stuck
in the up position and doesn't grab the link like it should. All the above plus lots of
wear and occasional miss handling makes it give the ghost. Best to get new parts, or
at least better used parts. Some links have a tiny snap ring groove to reduce the
pop out , marginally better.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 07-04-2013, 07:34 PM   #3
ken ct
I use mainly new ones with the extra groove for a snap pin and new and used ones i tap on the back side with a small ball peen hammer and puts a slight bow in the lever itself. Works like a charm. ken ct.
ken ct is offline   Reply With Quote
Old 07-04-2013, 08:13 PM   #4
Ray Balukas
Thanks, It is staying in the accelerator pump, but not the throttle. will try a slight bend. Can I put a spring clip on it? Thanks to All Ray
Old 07-04-2013, 08:38 PM   #5
ken ct
Not enough of the pin sticks through the hole for a pin. ken ct.
