Old 01-25-2024, 05:47 PM   #1
BrianCT
BrianCT's Avatar
Default Mass YOM plate how to check availability?
I need to see if the number has already been assigned. Is there a site to check it? I have gone through the MA RMV site but all they show is a form to register.I only want to see if it can be used.
Thanks
Brian
[FONT=Comic Sans MS]
BrianCT is offline   Reply With Quote
Old 01-25-2024, 06:00 PM   #2
TonyM
TonyM's Avatar
Default Re: Mass YOM plate how to check availability?
Register it and let them figure it out.
In Illinois, one need only to carry the legit modern plate in the car while using YOM plates.
Good luck. I hope you can find the answer.
TonyM is offline   Reply With Quote
Old 01-25-2024, 06:52 PM   #3
47fordguy
47fordguy's Avatar
Thanks
Brian
Massachusetts guy here. What I have done is to use this link: https://www.mass.gov/how-to/check-th...e-registration then select "Check your vehicle registration status online."
Entered the plate number and selected different plate types to see if any vehicle was registered using the plate number. Registry won't allow plates with duplicate numbers to be entered into their system, even if the duplicate number is on a different plate type.
No job is so important and no service is so urgent- that we cannot take time to perform our work safely.
-Bell System
47fordguy is offline   Reply With Quote
