04-30-2016, 09:23 PM | #1 |
8BA crankshaft
Any ideas on how to remove front hub from the crankshaft ( the piece the front seal rides on )
04-30-2016, 09:41 PM | #2 |
Re: 8BA crankshaft
I've heard of them being chiseled off. If the crank is out of the engine, pull it off ahead of the crank gear with a gear puller. We need more info about your need.
04-30-2016, 09:52 PM | #3 |
Re: 8BA crankshaft
H
Any mchine shop can remove it with little or no trouble. Why?? |
05-01-2016, 01:20 AM | #4 |
Re: 8BA crankshaft
You got the pulley off ?
Pull the cam gear a bit them drive it back in place again, that gives you a gap to use a puller to get the sleeve off. If youre not gonna reuse it grind a flat spot and break it with a chisel. |
05-01-2016, 07:14 AM | #5 |
Re: 8BA crankshaft
