06-27-2020, 09:03 PM | #1 |
1936 LB rods?????
Hello, is the stock rod for the 36 LB engine 18-6200? I know they can be replaced by the 21A rods, but they are heavier, building a stock engine.
Thanks |
06-27-2020, 10:12 PM | #2 |
Re: 1936 LB rods?????
You are correct, I use the 21A or 91A rods in all my 21 stud rebuilds. I get all my engines balanced....
06-28-2020, 02:21 AM | #3 |
The rod weight for the 18, runs 477 - 481G For the 21A its, 474.5 - 486.5G All the small end weights are nearly the same but, the 21A has a larger tolerance. The 48 rod, is lighter though at 462 - 468G. The weight difference on it, I believe is in the cap, itself. It's a little hard to read but, this is the actual Ford spec for those rods. I don't have the weight info for the 91 rod though, it appears that any increase in it's weight, would be do to weight of the cap, itself.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline Last edited by frnkeore; 06-28-2020 at 02:26 AM. |
