Old 12-22-2019, 05:03 PM   #1
lotsagas4u
Default 33 grease fitting????
Hello, have a problem with a lower king pin grease fitting on my car, tried everything I can think of, cannot get grease into this fitting. There is a hole drilled through the bushing, I have used heat, tried one of those pressure/hammer blasters, nothing works. I don't want to take it all apart, any other ideas? Thanks
lotsagas4u is offline   Reply With Quote
Old 12-23-2019, 09:52 AM   #2
Anteek29
Anteek29's Avatar
Default Re: 33 grease fitting????
Have you thought about replacing the grease fitting?
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 12-23-2019, 11:29 AM   #3
cas3
i would unhook the tie rod so you can wiggle it back and forth to feel the drag. remove the zerk, then try to wash it out with spray penetrating oil while wiggling at the same time. once you get the crud washed out and it moves free it should take grease.
Old 12-23-2019, 11:48 AM   #4
Mart
Mart's Avatar
Good advice above. Not mentioned but probably obvious is to have it jacked up while doing this.
Mart.
