Old 07-30-2020, 01:21 PM   #1
1bali-rod
Default Diamond block engine complete
Complete A diamond block engine.
Runs very nice and smooth.
Located in So Cal 92886
$1500
714-718-4591
1bali-rod is offline   Reply With Quote
Old 07-30-2020, 02:00 PM   #2
McMimmcs
McMimmcs's Avatar
Default Re: Diamond block engine complete
You might consider posting on FordBarn Swap Meet!
McMimmcs is offline   Reply With Quote
Old 07-30-2020, 05:39 PM   #3
Chris Haynes
Chris Haynes's Avatar
What are the differences/improvements to the diamond A Block?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 07-30-2020, 08:29 PM   #4
Synchro909
Synchro909's Avatar
There has been much discussion about that. I am of the opinion that there is really no difference better or worse. I have a diamond B and a diamond A engine and can see no difference. The general consensus seems to be that the diamond engines were produced after general production for cars ceased. These engines were used in industrial or agricultural equipment.
I'm sure others will chime in.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-30-2020, 09:09 PM   #5
goodcar
Engines used on some ag machines, Gleaner combines for example, only ran during harvest season, therefore fewer total hours. May be other differences, I don't know.
goodcar is offline   Reply With Quote
Old 07-31-2020, 11:46 AM   #6
Jim Brierley
Diamond engines, both A and B, were produced at least up to the war. They have a date cast into the block on the lower right front. Sometimes the dates are hard to decipher, but are there. Most, if not all had hard exhaust seats, all diamond castings were not the same, in thickness around the ports, etc. The diamond is a foundry mark so not produced on the Ford assemby line. The mark can be found on heads, bell housings, rear trans nounts, etc.
Jim Brierley is offline   Reply With Quote
Old 07-31-2020, 09:24 PM   #7
Gary WA
Gary WA's Avatar
http://www.fordgarage.com/pages/diamondblock.htm
www.whidbeymodelaclub.com
Old 07-31-2020, 09:26 PM   #8
Gary WA
Gary WA's Avatar
Thanks to Vince for the great info and his website. fordgarage.
Old 08-26-2020, 08:12 AM   #9
1bali-rod
Sold
