Old 07-29-2020, 06:37 PM   #1
bosticjb
Default Distributor
I can rock my distributor back & forth in the block question is how much play should there be
bosticjb is offline   Reply With Quote
Old 07-29-2020, 06:42 PM   #2
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Distributor
There is a set screw and locking nut below the distributor near the top of the intake manifold. Set screw snug, then tighten jam nut.
Old 07-29-2020, 06:59 PM   #3
bosticjb
Would this being loose create a viveration in the engine
Old 07-29-2020, 09:17 PM   #4
chrs1961815
chrs1961815's Avatar
Possibly. It also isn't good for the bushings.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-30-2020, 07:20 AM   #5
rocket1
Make sure the pin at the base of the distributor is firmly seated in the head.
rocket1 is offline   Reply With Quote
Old 07-30-2020, 12:20 PM   #6
Patrick L.
Patrick L.'s Avatar
Like Rocket1 said, there is a locating pin.
Patrick L. is online now   Reply With Quote
Old 07-30-2020, 04:31 PM   #7
john in illinois
john in illinois's Avatar
Like Chuck said tighten the set screw snug,not tight and hold it with a screw driver so the lock nut does not tighten it further. Too tight an the distributor can get distorted and the bushing will . Seize. Brattons catalog has this information. a friend locked up his distributor.
Best to error on the loose side,the pin will hold it.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-31-2020, 01:05 AM   #8
Big hammer
How much play? I recently rebuilt my distributor and NO play after the reinstall, I replaced the locating pin and cleaned some paint out of the head hole for the pin so it would go in.
The set screw should only keep the distributor down and not from turning IMO
get a bigger hammer tap done
Thread Tools
Display Modes
